10-17-2018, 03:06 PM | #1 |
Rep 14
Drives: F32 435i M sport
Coral red leather wear! Help!
Recently I have noticed the driver's side door has some wear in the leather. I have heard that the BMW is very soft but is there anything I can do to fix this? The car is under warranty until February but I don't think something like this would be covered.
Any and all suggestions would be appreciated! Thanks! |
10-17-2018, 04:02 PM | #2 |
Rep 6,069
Doesn't hurt to bring it to the dealer to see if they will cover it.
kchildsf3220.00 |
10-17-2018, 04:22 PM | #3 |
Rep 878
The 2nd picture shows what looks like bubbling, have you tried to clean it with something alcohol based?
kchildsf3220.00 |
10-17-2018, 04:25 PM | #4 |
Rep 14
10-17-2018, 04:53 PM | #5 |
Rep 378
That definitely does not look like regular wear and tear on Coral Red leather. I doubt the dealer will help you much here because it looks like the area was mis-managed. Either way, it doesn't hurt to try and see if they can cut you some slack and clean it up for you as best as possible. Good luck man.
kchildsf3220.00 upsidedownfunnel2002.50 |
10-17-2018, 05:38 PM | #6 | |
Rep 10,473
The only good news is that of all the leather parts you could have damaged, part number 51417345385 at less than $300 MSRP is the cheapest leather part you could have damaged. Your sweaty arms damaged it and even redying will not work long term for same reason. For the difference between redying and replacing, replace it. Next time eBay runs a 15% or 20% off code, you could pick it up for less than $200. https://www.ebay.com/itm/Genuine-BMW...5/192568839142 Last edited by IK6SPEED; 10-17-2018 at 05:43 PM.. |
