10-18-2018, 03:06 PM | #1 |
Rep 64
763m fit on M2 competition?
Do the m performance 763m wheels in m3/4 sizes fit on the M2 competition?
Front 19” /265 Rear 20” / 285
2013 F31 325d Mpack
2012 E82 1M coupé 1975 E9 3.0 CS |
10-18-2018, 03:19 PM | #2 |
Rep 466
10-18-2018, 03:23 PM | #3 |
Rep 3,660
Drives: 981 Cayman GTS
They do fit. There are some OG M2 owners running 20" 666m wheels (265/30/20 front and 285/30/20 rear) from M3/M4 Comp. 20" rear 666m has the same offset as 20" 763m so it should fit without any problem.
10-18-2018, 03:46 PM | #4 | |
Rep 466
10-18-2018, 04:02 PM | #5 |
Rep 3,660
19" front/20" rear setup is intended for M3/M4 but also fits on M2 with no problem. Why do you think you made a mistake? No, it won't make any noticeable difference assuming you are running the same width tires on both wheels. If anything, 19" rear 763M is slightly lighter than 20" rear 763m. If I were buy a set of 763m for my M3/M4, I would still go with 19" all around as opposed to the recommended 19"/20" setup. But you wouldn't notice any performance difference anyway as long as your tire setup isn't something crazy to upset the traction control (if you drive with DSC or MDM).
10-18-2018, 05:03 PM | #6 | |
Rep 2,808
So any old 19" wheel with the right offset won't work. The one I tried, the spokes cleared the calipers, but not the barrel. I would still have to source used 763M wheels, but at least it's another option. I don't feel like spending 500 bucks a wheel right now on the OZ ones Tire Rack sells. |
10-18-2018, 05:08 PM | #7 | |
Rep 3,660
10-18-2018, 06:43 PM | #8 |
Food Critic
1086
Rep 1,015
What 19" wheels are you trying, and what offset? What if you do an offset of say +23 in the front? That should clear for sure right?
10-18-2018, 07:59 PM | #9 |
Rep 2,808
You're probably right, I had them confused with another set of wheels. I thought these were the stock wheels of the M2, and hence, I might find them easily used.
They're $700 to $800 new, so it doesn't matter if I find them used anyway. I might as well go aftermarket and get new. |
10-18-2018, 08:02 PM | #10 | |
Rep 2,808
It's the barrel of the wheel that is rubbing, because the OEM wheels have some form of channel / indent just behind the spokes to allow the calipers to clear the barrel too. |
Protatomonster275.50 Flunx4.50 |
10-18-2018, 08:30 PM | #11 | |
Food Critic
1086
Rep 1,015
8.5" w/35 offset is actually 12mm less than stock (stock is a 9" width) and I'm actually surprised that the face cleared at all given how close the spokes are to the brake. I'm not necessarily seeing the groove but it definitely looks like it "barely" fits. I would think that even if there's a groove, that doesn't effect clearing the barrel because the entire barrel would have to be the same depth as the groove otherwise you couldn't put the wheel on in the first place. I'm really curious because until now in choosing my aftermarket wheel I've been looking at offset only... I'm concerned if there are barrel clearance issues.
10-18-2018, 09:44 PM | #12 | |
Rep 2,808
I tried to take some pictures of the front wheel just now, and as you can see, there's about 3.5 cm (1.5") of space between the spokes and the caliper, down to just under 2.5 cm (1") at the lowest. So it doesn't surprise me that 12 mm retraction of the outer edge might not have scraped. But the whole thing does totally puzzle me, why a 19" wheel didn't fit. I thought the wheel diameter was the easy part. Talking to Apex, with whom I might go now, they said that some 19" wheels are made to clear big brakes, like their 19x9" ET30 SM-10 Wheel, but not all are. I guess That's why their 19x9" ET28 APEX ARC-8 isn't listed on the other hand, as a fit for this car. . |
10-18-2018, 11:00 PM | #13 | |
Food Critic
1086
Rep 1,015
10-19-2018, 12:02 AM | #14 | |
Rep 2,808
For reference, here are the two wheels: https://www.apexraceparts.com/shop-b...-10-wheel.html https://www.apexraceparts.com/wheels...c-8-wheel.html They told me they know the SM-10's work with big brake kits, and the M2C has 400 mm rotors, slightly smaller than the M2's or the M2 carbon ceramic brakes which are 410 mm - can't remember which he said - with which they have been tested, so that's why they're confident and it's the only 19" wheel they say will fit the M2C. The 19" ARC-8's in fact have a lower offset even, so if that was the main thing, they should fit too, but they don't list them as a fit. |
10-19-2018, 03:02 AM | #15 |
Rep 771
Drives: LBB M2C, VO 1M, GSA 1200
Garage List 2021 BMW X3M Compet ... [0.00]
2019 BMW S1000R [0.00] 2019 M2 Competition [0.00] 2018 BMW 1200 GSA [0.00] 2011 1M Coupe [9.75] |
I posted this in another thread, but seems relevant to issues fitting 19" wheels on M2Cs equipped with the big brakes (2NH).
I have a set of 19" Blizzaks mounted on VMR wheels (19x8.5, 19x9.5) which I have used on my 1M. Was hoping to use these on the M2C this winter, but the 19" VMR wheel doesn't clear the front brake caliper. The surface of the inner barrel is slightly raised, narrowing the inner diameter, and preventing the wheel from clearing the brake caliper. I measured the inner diameter of the VMR wheel barrel which is only 18". The OEM 788 wheel measures 18.5" internal diameter, providing enough clearance for the caliper. |
10-19-2018, 07:10 PM | #17 | |
Food Critic
1086
Rep 1,015
Flunx4.50 |
10-20-2018, 12:25 PM | #18 | |
Rep 2,808
So as of this point, the cheapest non OEM options seem to be Apex SM-10's at around $400 a wheel (they've confirmed they clear BBK's), or the OZ HYPER GT HLT from Tire Rack (assuming their fitment calculator's correct). |
cptobvious2531.50 |
10-20-2018, 02:01 PM | #20 | |
Rep 2,808
PS Does he sell wheels with tires mounted also, or just wheels? I posted in another thread my experience at a shop with a set of 8.5" ET 35 wheels: Today I went to my local wheel shop, and the test fitted a 19" BMW replica wheel on the front. The OEM front wheel is 19 x 9", ET 29. The wheel we tried was 8.5" wide, with 35 offset, and the side of the rim did NOT clear the brakes unfortunately. |
Flunx4.50 |
10-20-2018, 03:22 PM | #21 | |
Rep 614
Flunx4.50 |
