BMW 5-Series (G30) Forum Engine, Exhaust, Drivetrain, Tuning Modifications Exhaust Valve on 540i Msport
      10-22-2018, 08:59 AM   #1
MN
Drives: Bmw 540i XDrive M Sport
Hi guys
I want to try and remove the valve/flap on the right exhaust so that it remains open in all modes at all times. I dont have the skills to do it myself (wee, the space mainly), so i was wondering how to go about it. I asked Sytner when i got it new to do it but they said it would affect the warranty so they didnt.
Any help would be appreciated.
Thanks!
      10-22-2018, 09:46 AM   #2
ksoze
ksoze's Avatar
Drives: 2018 M550iX
https://g30.bimmerpost.com/forums/sh...3&postcount=19
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
      10-23-2018, 03:46 AM   #3
MN
Originally Posted by ksoze View Post
Many thanks! will try that
      10-23-2018, 11:09 AM   #4
MN
Tried this just now but doesn’t work. The flap isn’t open on firing up or even when you gas it. Any ideas guys?
Thanks
      10-23-2018, 11:59 AM   #5
ksoze
ksoze's Avatar
Drives: 2018 M550iX
May be a M550iX thing. 540 flap may only open under heavy acceleration.
      10-23-2018, 02:02 PM   #6
MN
I think so.
Looks like I have to try the spring thing or go for the MPE in the future
      10-26-2018, 05:27 PM   #7
Bklynjoker
Bklynjoker's Avatar
85
Drives: G20 %E2%80%9C22%E2%80%9D MSpor
Tried this just now but doesn't work. The flap isn't open on firing up or even when you gas it. Any ideas guys?
Thanks
I have a 19 540MSport. I use the Carly app if I wanna open or close the flap... I haven't tried that fuse method. Down side is I would have to connect to Carly every time I wanna open.
The flap opens on mid/heavy throttle, On any mode. I don't think it opens on drive modes buttons
LeXxiNGToN aka LeXxDiAMoNDS
      10-27-2018, 04:59 PM   #8
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
Use carly to open it once then pull the fuse to keep it open?
I did try the mechanical method (cable tie) on mine to keep the flap open, and it was still pretty quiet and civilized on idle (after the initial start up raor which is not flap related), and also sounded the same when accelerating hard (because the flap would have been open anyway). When cruising, there was not a noticeable difference either. So I put everything back as it felt rather pointless.
      10-28-2018, 12:17 PM   #9
Bklynjoker
Bklynjoker's Avatar
85
Honestly yeah it may feel cool with the flap open but theres not much noise to make it that cool lol. Just alil humm when driving that prob only You can hear.
I had a "14" x5 3.5 Stage1 with OEM flap exhaust and When i hit boost hard then shifted 1st-2nd around 4K rpm the whiplash sound that came out was effff'in crazy where people got scared. I was hoping these B58M setup did the same. Pretty Wack I can't make the same shift sound with this OEM flap.
      10-28-2018, 03:20 PM   #10
NicoleLusts4BMW
BeachBitch
NicoleLusts4BMW's Avatar
Drives: 2018 540i M Package 20" wheels
Why?
      02-07-2019, 09:38 AM   #11
Davg31
Belgium
110
Drives: G23
429 euro
https://www.active-sound.eu/fr/bmw/5...-valve-control
      02-07-2019, 12:39 PM   #12
ozwol
Drives: f31 335d g31 540i
Originally Posted by Davg31 View Post
Exactly what Im after.... thank you.
      02-07-2019, 12:58 PM   #13
Davg31
Belgium
110
Drives: G23
I had it installed in mine this morning, it works fine.
      02-07-2019, 03:12 PM   #14
ozwol
Is it just a simple plug into the obd type unit...doe's it require any technical know how, if it does Ill struggle.
Thanks
      02-07-2019, 07:03 PM   #15
Davg31
Belgium
110
Drives: G23
Hello, the installer took 1h30, he plugged it in easily, they just had to look for it to get the cable through without dismantling everything.
      02-07-2019, 07:05 PM   #16
Davg31
Belgium
110
Drives: G23
https://youtu.be/FF-Ff_J7SBw
The video that shows the difference in noise (Remus)
      05-06-2019, 12:02 PM   #17
hlothery
Seeking mental floss
482
Drives: 2022 Mercedes EQS 450+
I just tried the fuse thing. Had to blip to 4K in Sport Plus to get the valves to open. Verified by feeling exhaust from both pipes each side. The fuse diagram doesn't look anything like my car. Pulled what appeared to be the only 7.5A fuse on the fusebox (I'm not an electrical engineer). Didn't work. Finally noticed the diagram folded in the fuse box, which shows exactly where 203 is. Pulled it. Thanks for the help.
      05-07-2019, 09:59 AM   #18
Warp Ten
Warp Ten's Avatar
Drives: 2019 BMW 540xi
I just opened my flap yesterday. Removed the spring clip with a pair of needle nose pliers and wired it open with some 12 gauge electrical wire, twisting it tight with a larger pair of regular pliers. Took 5 minutes; little skill required. Hoping for a little improvement in sound but no change that I could discern. Going to add an M Performance exhaust sometime soon I think. --Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
      05-07-2019, 10:24 AM   #19
NCMMichael
Drives: 2019 BMW 540i
You would think I would know this, but the thought never occurred to me. I added the MPE and the Dinan Elite v2 tune. While the MPE note is fairly subtle at idle, I'm pleased with the improvement (sound and drivability). I assumed the MPE still utilized the flap in comfort, but I honestly never drive in comfort. Is the flap completely eliminated with the MPE?
      05-07-2019, 10:27 AM   #20
Warp Ten
Warp Ten's Avatar
Yes, there are no exhaust flaps with the MPE.-Bob
5post
