10-24-2018, 07:14 AM | #1 |
Rep 29
When do you replace an RE71?
It looks there is a wear bar between the center treads. Do you go all the to that point?
My outer edges are really chewed up. Is there post somewhere to help newbies understand the RE 71? Thx |
10-25-2018, 12:40 PM | #3 |
Rep 3,505
Or, when the tire has become hard enough that it no longer grips to your satisfaction. Time, heat cycles, and storage conditions all affect the rate at which a tire hardens.
I use the 'fingernail test' on my performance tires. That is, I test them by regularly pressing my fingernails into the tread rubber. This gives me direct feedback regarding the rate at which they're becoming harder. Ambient temperature has an effect, so when possible it's useful to do these checks at the same temperature.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
Dylan861330.00 |
10-25-2018, 06:43 PM | #4 |
Rep 969
It depends on whether you are willing to flip your tires or not. Flipping tires takes the worn side and flips it to the inside where the tire is not in prime contact when you realize camber gain at the extremes. If I am going to flip a set, I'll go roughly 3-4k miles and 50-60 runs, and then flip knowing that first event post flip will suck. This allows you to get about 7-8k miles and about 120 competitive runs out of a set. The BS are pretty good down to the very last bit 2/32's which is below the first wear bars.
Sold 2011.5 E92 M3 ZCP.
11-14-2018, 10:23 AM | #5 |
Rep 1,931
till they cord. As they slick out, dont run them in any wet.
you can run these as slicks.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
Tags |
re71r |
