N52K oil leak
10-25-2018, 02:10 PM | #1 |
Rep 418
N52K oil leak
There is a oil leak on my 07 328i and I think it is the valve cover. The oil is dripping on the exhaust somewhere and burning. I can smell and see some smoke. I noticed that one the the bolts on the left rear of the engine was missing and two were lose. I replace the missing one and tightened the loose ones, but it didn't fix the problem. I was using a mirror and noticed the left rear corner was sticking up some. it is the wrong bolt in it. I switched it out with a different bolt but I still think it is the wrong type of sleeve on it. Is there a diagram that shows exactly what each bold should be? I'm not %100 sure that the valve cover gasket is where the oil is coming from. Is there another spot that is common for leaking oil?
Thank you |
10-25-2018, 02:54 PM | #3 |
Rep 418
I think I will have to. I would like to try to get a temp fix for the winter. The gasket was replaced on 2016 but I don't think the shop knew what they were doing. I still need to figure out what bolt goes where.
10-26-2018, 06:11 PM | #6 |
Rep 5,023
10-27-2018, 07:58 PM | #8 |
Rep 788
10-27-2018, 09:12 PM | #9 | |
Rep 5,023
Be sure to thoroughly understand the valvetronic removal and install procedures with the Allen wrench. It’s not rocket science but can be screwed up. |
10-28-2018, 12:50 PM | #11 |
Rep 5,023
Not if you do it right. You’ll hear the motor relearn on it’s on once ignition is switched on. Dont deviate from the Pelican Parts DIY.
Check that out. Not trying to scare you. It’s very do-able just don’t go in blind and you’ll be fine. |
10-28-2018, 03:46 PM | #13 |
Rep 85
Good vid on the process.
Tip: when you get the beauty cover off, pull up the connector on the Eccentric Shaft Sensor and examine the inside of the connection for oil (watch the vid for the location). If there is any in there, meaning oil is being forced past the connector pins from inside the ESS, the ESS is reaching end-of-life and you should replace it while in the valve cover. The unit is stupidly expensive, but if it fails in the next year you'll be pulling the valve cover again to replace it. You can button it back up and get a best price ESS replacement (might take a couple of days to order it up), then complete the job when you have the new ESS in hand.
2007 530I, 2007 328xiT
2003 325XI (gone) 2004 530I (gone) 2001 530I (gone) BMW CCA Member 15+ Years Last edited by banglenot; 10-28-2018 at 04:07 PM.. |
