E90 335xi Transmission Jolting After Fluid Change
12-06-2018, 08:54 AM | #1 |
Rep 92
Drives: 2007 BMW 335xi
'07 335xi with the ZF 6HP19 that had a cracked Mechatronic adapter (square seal) that I replaced. I had Pentosin ATF1 in the tranny when I did a fluid change about 2 years ago. This time around, I used Valvoline MaxLife which meets the Shell standard needed for the tranny. Read many posts and people did not have issues with it. I properly filled it up (took about 4.5 liters), cycled the gears, drove around, refilled, etc. I know I have the proper level, but ever since the change, I have a jolt in between 1st and 2nd gear, but only between those gears though. Could it be that the oil is too thin at operating temperature but OK when cold? I also only get this issue after the fluid is warmed up, after about 10 minutes of driving. When cold or any other shift above 2nd gear, the shifting is buttery smooth. Any ideas? I know many of you will say to put the right oil in, but looking at other workarounds for now. what's odd is that when the tranny is rough shifting, I perform a tranny reset and all is good after that, but then the issue creeps up again.
12-06-2018, 09:18 AM | #2 |
Rep 1,753
Wrong fluid/wrong qty. These are the two most likely reasons.
I have done this job and had ZERO problems. So before you respnd back really consider what i am telling you because i have succeeded. |
12-06-2018, 10:15 AM | #3 |
Rep 92
Yes, I understand that this might be the cause. As far as the quantity, I believe I am OK. My INPA isn't communicating correctly with my tranny, so I cannot use it to check my fluid temperature. I did let the car idle for about 2 minutes, then add the remainder of the fluid. Hopefully that was enough for it to reach between 30-50 celsius.
12-06-2018, 10:21 AM | #4 | |
Rep 223
12-06-2018, 10:24 AM | #5 | ||
Rep 92
12-06-2018, 12:08 PM | #6 | |
Robot
1698
Rep 2,196
Where did you see that MaxLife that meets the Shell M-1375.4 standard? In all of my research, reading online and looking at bottles in several stores, I didn't see any evidence that the MaxLife Multi-Vehicle ATF meets the M-1375.4 standard. I have seen old forum posts from 2010 and 2011 with some claims from individuals that the MaxLife Multi Vehicle ATF is "suitable for applications requiring M-1375.4" but have not found anything from Valvoline stating that. I could be wrong, but I just haven't seen anything. It's possible that the fluid is not the correct viscosity and the existing adaptations in your car are tailored for the old fluid, causing the harsh shifts. If you cannot confirm that the MaxLife ATF meets the M-1375.4 spec (not 'suitable for use' but actually certified/licensed/etc.) then I would suggest changing to the correct fluid. Personally I use Mercon SP which does NOT have the M-1375.4 approval, but from all the reading I've done I've determined that it's nearly identical to the ZF Lifeguard 6 fluid. It significantly improved all the shifting in my transmission. I previously had a harsher 1-2 shift as well (only in DS mode when not aggressively accelerating) however that's gone now. I also had a slightly harsh 2-1 downshift when coming to a stop but after a month of driving with the new fluid that is gone. Another comment on the MaxLife ATF, the bottle claims it's suitable for use in applications requiring Honda ATF-DW1 so I used that recently in my Pilot, however the shifts feel a bit sloppy compared to the original fluid, so I'll be looking for something else next time. Last edited by lowrydr310; 12-06-2018 at 01:52 PM.. |
12-06-2018, 12:38 PM | #7 |
Rep 92
Thanks for the reply. I'm surprised the Mercon SP worked for you even though it's a Ford fluid. I personally believe my fluid is too thin and is causing issues. Since I mixed 50/50 MaxLife and Pentosin at this point, I'm going to have to do a full flush...all 9-10 liters and I read that it can get tricky and not advised to empty the torque converter.
Here is the spec sheet for the Valvoline MaxLife. On page 1, about 3/4 page down on the left side, you will see that it meets BMW M-1375.4 https://sharena21.springcm.com/Publi...2-ac162d889bd1 Last edited by danfratamico; 12-06-2018 at 12:46 PM.. |
12-06-2018, 12:57 PM | #8 |
Rep 1,753
Not filling between 30- 40 is your issue. You have to fill at this temp range. This is a very important part. Overfilling causes heating (transmission damage). Underfilling causes shifting problems.
DO NOT FILL without knowing the transmission temp... 2 minutes waiting means nothing. How is that a reference of any kind ? Do the job properly do it once. |
12-06-2018, 01:06 PM | #9 | |
Rep 92
12-06-2018, 01:59 PM | #10 | ||
Robot
1698
Rep 2,196
In my case I didn't mess with the adaptations and the fluid change alone showed an immediate improvement in shifting. It only got better over the next month or two, presumably from the adaptions being updated automatically as I drove more. The harsh 1-2 shift or 2-1 shift is common in these transmissions, even with the correct fluid, and it seems that replacing the solenoids (~$250 for the parts, need to drop the pan to get to them) has a good track record of fixing the problem. If you're going through the effort of doing another fluid change, you might want to order a new pan (has an integrated filter) and a set of solenoids and replace them too. |
12-06-2018, 02:09 PM | #11 |
Rep 92
By resetting adaptions, what does that entail? Ignition on, accelerator pedal to the ground for 30 seconds, ignition off? Is there more to it? If not, then I have reset it multiple times and same thing.
12-06-2018, 04:59 PM | #12 | |
Rep 1,753
Not sure about how transmission fluid can get in the front of the car.. |
12-07-2018, 07:18 AM | #13 | ||
Rep 92
12-07-2018, 08:09 AM | #14 |
Rep 460
We've been running Mercon SP in our 2007 335i for 2 years and 20,000 miles with no issues. I did a simple drain and fill. I did also replace the transmission pan and filter (they are one) at that time too.
12-07-2018, 08:15 AM | #15 |
Rep 92
I read that the Febi fluid is approved for these trannys. Found a great deal on eBay, 10 liters for $115. Going to order that, a new pan, already have OEM gasket, and see what happens...
12-07-2018, 09:58 AM | #16 | |
Rep 1,753
If you cannot do that you cannot replace the fluid.. FEbi is what i am running.. no issues. |
12-07-2018, 11:25 AM | #17 | ||
Rep 92
12-11-2018, 02:41 PM | #18 |
Rep 92
Does anyone know where the transmission oil cooler is on my E90 335xi? If I am looking at the diagram correctly, it is on the right side of the radiator when looking at the car from the front.
12-11-2018, 09:22 PM | #19 | |
Rep 31
An SRT/SVT guy that has fallen in love with BMW......
A guy trying to get his E90 back to its Smooth Running glory and then Tune it to beat my 06? SRT8 Magnum |
12-27-2018, 08:12 AM | #20 |
Rep 92
Ok, so I drained about 4.5 L of my red MaxLife fluid and pumped in new Febi oil which was much thicker. I properly topped up the fluid this time when my tranny temp was at 40C. One thing I am noticing now is when the engine and tranny are cold, the tranny flares into certain gears and is a bit jumpy. It will be like that for the whole trip pretty much until I shut my car off. If I turn my car on right away, the shifting is buttery smooth and I have absolutely no issues. Can anyone explain? I reset adaptations via INPA, but maybe I need to just let it learn? If I had an issue in the tranny, I'd think the issue would be evident all the time.
12-27-2018, 11:09 AM | #21 |
Rep 709
It seems that resetting adaptation requires the very lengthy procedure of relearn.
See https://www.e90post.com/forums/showthread.php?t=1536089 And looks like I have the GM not ZF, and now I can't find the proper procedure for it and experiencing harsh shifts on the lower gears. |
12-28-2018, 09:18 AM | #22 |
Rep 460
As others have said the correct fluid level and temperature 30-50C seem to be critical when filling the ZF transmission. On a past fluid change I was 1/2 a quart low and the transmission shifted like crap. Went back and did the procedure again with the correct level and temp and it shifts like new now.
