12-09-2018, 12:01 PM | #1 |
Rep 20
Winter Tire Package from tirerack
New BMW Owner just got my New 2018 X3 M40I
Looking for winter tire packages, Tire Rack gives me this setup below but not sure if it will clear the brakes or fit proper. Any feedback will help thank you And has anybody found winter tires in 21 or tried using? Front and Rear Size: 18x8 Offset: 35mm Backspacing: 5.91" Bolt Pattern: 5-112 Rec. Tire Size: 225/60-18 |
12-09-2018, 02:38 PM | #3 |
Rep 3,654
This is not entirely true. On every single thread I have to post this. Bmw recommends their 19" wheels. Some 18" aftermarket wheels will clear the msport brakes. It depends on the barrel and spokes. There are enough data points in the snow tire thread. No one has tried fitting 18" bmw wheels. Those are only 7" wide. I think they are very narrow (personal taste). |
12-09-2018, 03:49 PM | #4 |
Stay Tuned!
298
Rep 390
I have 18s on mine and they work fine.
I agree with arciga18 that there is a lot of misinformation. Not ALL OEM BMW 18s fit so BMW takes the high road and say that none fit. Here is my full write-up: https://x3.xbimmers.com/forums/showthread.php?t=1556515 Tire Rack guarantees it will work or you don't have to buy (I assume this is because I picked them up at the depot). Paul Last edited by Jeepersjoey; 12-09-2018 at 03:57 PM.. |
arciga181732.50 |
12-09-2018, 04:15 PM | #5 | |
Rep 3,654
This misinformation regarding 18s is getting old . |
12-09-2018, 07:00 PM | #6 |
Rep 20
I do not quite understand tires that well.
If i go to 19 does that not mess up the rotation so now the car thinks i am doing less or more Km or does it not work that way? thanks |
12-09-2018, 07:03 PM | #7 |
Rep 3,654
12-10-2018, 06:21 AM | #8 | |
Rep 228
Drives: 2018 X3 M40i
https://www.willtheyfit.com/ |
