Ways to prep a surface before new gasket?
12-12-2018, 11:30 AM | #1 |
Major Private First Class
450
Rep 1,327
Drives: 2010 E90 335i M Sport
I'm doing the VC, OFHG, and just did the transmission oil pan/filter. I tried using brake cleaner to clean the surface before installing the new gasket + transmission pan but honestly, I'm really not impressed with the stuff.
Any suggestions on a sanding block that isn't harsh to the surface but will remove residual from the gasket? I just want it to shine but I can't get rid of some of the lines left from the shape of the gasket. I don't want to mar it or make it uneven for obvious reasons. Would a scotch brite work? Thanks
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
12-12-2018, 01:01 PM | #2 |
Rep 952
Yes a scotch brite will work, but start with a less aggressive one. Just like sandpaper scotch brite comes in grades of coarseness. Start with one that is scratch free and use it in combination with either brake cleaner or another petroleum based solvent. You can then move to ones that are coarser if that is not working. I also find a plastic putty knife works well until the edge gets too dull.
bone stock
N54Society449.50 |
12-12-2018, 01:32 PM | #3 |
Hoonigan
6894
Rep 3,001
Drives: '09 328i, '98 Wrangler
+1 on the less aggressive scotch brite. I also have some of those plastic razor blades from amazon that work really well for scraping gaskets.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
N54Society449.50 |
12-12-2018, 02:07 PM | #4 |
450
Rep 1,327
Thanks guys!
12-12-2018, 02:24 PM | #5 |
Rep 564
I'll probably use something like this when I do all my gaskets
https://www.eastwood.com/eastwood-4-...raper-set.html |
12-12-2018, 02:26 PM | #6 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
I usually just use paper towel, brake cleaner and a plastic razor
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
