E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 318D Troubles
Reply
      12-12-2018, 03:50 PM   #1
P3rxg
Guest
n/a
Drives:
318D Troubles
I'm gonna cut straight to the chase, I have a 318D E91.
About 2 months ago I bought a BlueSpark tuning box, put it on max setting and it was working fine for a couple of weeks then the EML came on. So I knocked it down a setting which caused the light to go out and everything was fine again. Some time down the line I noticed a problem between 1500-2000rpm, sometimes when going around roundabouts I would experience some kind of power loss or a misfire, if I keep the rpm between this range on a straight road I can feel some sort of small jerks (very subtle) as if something is pushing back on the car. I have plugged my car in and got P3043, P0101, P0402. I have taken the EGR off and cleaned it, replaced the Mass Airflow Sensor and it still hasn't fixed my problem. I'm now considering a bad fuel pump? MAP sensor? Injectors? No idea what's going on and btw I have taken the box off and the problem persists.
Please could someone point me in the right direction?
      12-13-2018, 07:08 PM   #2
feuer
feuer's Avatar
Drives: wife crazy!
Originally Posted by Raakhuga View Post
If you're experiencing actual missfires i would opt for new spark plugs, if the fuel pump is broken check when you turn the engine to second contact if the fuel pump pre-pumps fuel, but the car shouldn't even start if the fuel pump is broken .. ofcourse im new to the forum and i also recently bought my first BMW, also a E91, are you sure it's not just your traction control on roundabouts ? 😅 check if the engine idles Badly and/or irregular, in that case iT COULD be the spark plugs. I'm no expert though
Definitely you are NOT and expert as 318d doen NOT have spark plugs.
      12-14-2018, 03:26 AM   #3
juld0zer
Australia
482
Drives: Prev 135i 7DCT, Now 130i 6sp
Take the shitbox off?
Sometimes you have to pay to play and running a tuning box on its maximum setting on a stock engine is asking for trouble.
What year is your car?
      12-14-2018, 06:21 AM   #4
P3rxg
Guest
n/a
Drives:
The box is off, the year is 2010
      01-10-2019, 03:34 AM   #5
juld0zer
Australia
482
Sooted intake ports?
Reply
e90post
