E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 Setting engine time issue- Vanos moves
Reply
      12-26-2018, 09:50 PM   #1
alvinhobh
Drives: 2007 BMW 335i Coupe
Timing issue. Need help.
Set the timing on my N54 with the timing tool, following aldata procedure and this DYI for reference (https://www.e90post.com/forums/showthread.php?t=1080990)
After all is done, as soon as I rotate the engine clockwise, I can see the vanos move in relation to the cam. and after 2 revs the alignments are out. The vanos have been out for a while, prob have no oil. Are they spring loaded or just oil ? How can I tell if it is bad? Any suggestions
      12-28-2018, 12:30 PM   #2
specialist
Drives: 335i
did you change the bolts? did you do the angle meter give it an additional 180 degrees?
Reply
e90post
