12-28-2018, 07:42 PM | #1 |
Rep 1
Alignment Issue for F32
Hi guys, I have done the alignment recently but seems the steering is still pulled toward the left side. Not sure is this in normal or some of the setting is out of spec
Here is the result Toe in, camber and caster are within the spec but the included angle for L&R side are 3.5 degrees in different As reference form this website http://aligncraft.com/terms/terms.html It states : Included Angle is the combination of SAI and camber. Viewed from the front, the included angle is SAI plus camber if the camber is positive. If the camber is negative the included angle is SAI minus camber. If a side to side variation greater than ± 1.5° exists, check for vehicle damage. Angle + Camber = Included Angle (I/A) Would there something bent and cause the steering being pulled? |
