12-31-2018, 08:13 PM | #1 |
Rep 928
Or Bmw performance springs even
Trying to decide. Don't want to lower more than 1" at the most. Won't see much track day but very aggressive street and occasional track days. I'm leaning towards AC Schnitzer as they lower slightly more than Dinan and I believe have slightly higher rates. I like the swift spec-r springs as they are linear and would handle the best, but would have the harshest ride. I will be pairing with Koni sport adjustable schocks/struts. Who has experience with any of these and hopefully have experienced more than one of these? Thanks!
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
01-02-2019, 10:14 AM | #2 |
Rep 141
Drives: 2016 BMW 340i RWD
[QUOTE=52172;24177726]Trying to decide. Don't want to lower more than 1" at the most. Won't see much track day but very aggressive street and occasional track days. I'm leaning towards AC Schnitzer as they lower slightly more than Dinan and I believe have slightly higher rates. I like the swift spec-r springs as they are linear and would handle the best, but would have the harshest ride. I will be pairing with Koni sport adjustable schocks/struts. Who has experience with any of these and hopefully have experienced more than one of these? Thanks![/QUOTE
My car is RWD, and I paired the Dinan Springs with the Koni sports about 4 months ago. I don't track the car, but it handles a lot better, and still maintains a stock like comfort ride. This setup gives me more steering feedback on the road. Initially when I had this done, I was running on 19" OEM summer wheels and tires, and I felt it was comfortable for daily driving. Last month, I put on my 18" OEM winter wheels with the 225 45/18 tires. The ride is lot more comfortable, as I don't really feel all the road imperfections. Like you, I was looking for a mild drop, and this setup has worked very well for me.
2016 BMW 340i | DINAN Lowering Springs | DINAN Stage 1 v1 Tune | DINAN Mid Pipe | DINAN CAI | DINAN Turbo Inlet Pipe | Koni Sport Dampers | BMS 12/15 mm Spacers | Active Autowerke Exhaust
01-02-2019, 11:38 AM | #4 |
Rep 141
I did purchase them, but my installer stated they were not needed, since the Koni are already shorter than the stock dampers. They re-used the existing bump stops, since they were still in very good shape. This was all done when my car only had 10K miles on it.
01-02-2019, 11:47 AM | #5 | |
Rep 928
01-02-2019, 12:16 PM | #6 |
Rep 141
Yeah I haven't noticed an issue with them. Here is a picture of the drop on my 19" OEM summer setup, as well with the 18" OEM winter setup.
01-02-2019, 12:20 PM | #8 |
Rep 141
Here is the Pic with 18" OEM Winter setup
01-04-2019, 12:42 PM | #10 | |
Rep 141
This can probably explain a little more on the adjusting: https://www.koni.com/Cars/Technology/Adjustment-Guides/
01-05-2019, 08:28 PM | #11 |
Rep 928
I'm going with swift spec-r and konis. It will have the best handling as it's a linear spring. I'll sacrifice a little comfort for handling. Won't need sways later.
01-08-2019, 06:11 PM | #13 |
Rep 928
It maybe a little while for spring install I'm having intercooler cp and dp installed first 😎
04-03-2020, 10:25 PM | #14 |
Rep 3,748
04-06-2020, 02:01 PM | #15 | |
Rep 928
