01-03-2019, 11:26 AM | #1 |
Bimmer Nut + Software Dev
555
Rep 802
Drives: 2018 Audi S3 IE Stage 1
Best way to clean this?
This is probably the only gripe I have with the F30 interior. The plastic gets this dirty gummy grime and I don't know how to properly clean it.
Any pointers?
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
01-03-2019, 11:41 AM | #2 |
Rep 16,197
I use this on my interior:
https://www.amazon.com/TriNova-Plast...=trinova&psc=1 It's marketed as a trim restorer, I found it restores all the interior surfaces to like new condition. |
whoismorggan555.00 Rebound152.50 |
01-03-2019, 01:14 PM | #3 |
A family of bimmers
2757
Rep 7,743
are you sure its grime and not just worn off?
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
01-03-2019, 01:27 PM | #4 |
555
Rep 802
Positive. The dirt will move around when I try to wipe it off. I end up just wiping it into a different place on the dash
01-05-2019, 02:06 PM | #5 |
Rep 4
If it is dirt I would use a very mild APC cleaner and a softish bristle brush to agitate. Then should be just a case of wiping off with a clean microfiber.
whoismorggan555.00 |
01-05-2019, 07:33 PM | #6 |
NewFinishColumbia/detailer
604
Rep 2,096
Like Kevin just said. Some all purpose cleaner like Mrs. Meyer's Clean Day diluted down to 5:1 and a soft brush will do the trick. You can find it at Target.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
01-10-2019, 08:25 AM | #7 |
Rep 1,703
Drives: 2014 428i and 2018 X5
use a toothbrush
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
01-10-2019, 10:56 AM | #8 |
Rep 277
Blu-tack?
02-03-2019, 11:05 AM | #9 |
Rep 129
You can use the gyeon Vinyl cleaner or the swissvax plastic cleaner in combination with a detailer brush.. They are both good products
02-04-2019, 10:35 PM | #10 |
Rep 14,145
Drives: G82 M4C X-Drive
Griots Interior Detailer and a nice microfiber cloth will take care of that.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
