2010 2011 BMW 5 Series Forum F10 Ambient Light Intensity Coding |
01-07-2019, 01:08 AM | #1 |
Rep 704
anyone coded their ambient light intensity? I tried to find one but no luck. There some for other f series but not with f10.
01-15-2019, 10:21 AM | #2 |
Rep 808
If you have the earlier f series I think the only way to adjust it is through the dimmer scroll on the headlight switch. On the newer f series it can be controlled independently through the idrive. Someone correct me if I'm wrong
01-15-2019, 05:49 PM | #3 |
Rep 704
I was thinking about the same thing that's why I just changed the OEM ambient light to LED.
01-16-2019, 06:49 AM | #4 | |
Rep 1,876
On my pre-LCI F10, the ambient brightness is controlled by the dimming control but prior to that integration level update was so dim it was pretty much never visible. Now at max dimming setting it can be quite bright. I'm not sure that the LCI F10 was any different. On much newer BMWs (e.g. any loaner I was ever given) you can set colour and intensity in idrive as mentioned. |
03-31-2019, 08:35 AM | #5 | |
Rep 7
Drives: Bmw 528i
Do you have any pictures and/or infomation on switching the Ambient Lights to LED? I'm planning on switching all doors and adding a strip under the dashes edge as well but want to be able to change the color. I saw a guy do it on youtube for the F10 but he didn't wire them all together so he had to flip a switch on each door... |
