01-09-2019, 10:32 AM | #1 |
Rep 420
USB - Charging Voltage in Built In Ports?
Hello fellow readers,
I picked up my new X5 early December and am still in awe of how different this is from my '16 X5. I am impressed with how much connectivity the vehicle offers but curious to know what the ports can handle. I recently picked up the "travel & comfort" table for the rear passengers (my two toddlers) and would like to know if those rear ports can handle charging iPads? What can the front and mid console ports handle? Lastly, is the wireless charging bay a fast charger? I do not have a USB voltage meter but would request if a forum member does would you mind posting the results for the group. Many, many thanks in advance. |
01-09-2019, 10:34 AM | #2 | |
Rep 579
01-09-2019, 10:44 AM | #4 | |
Rep 4,246
2.3.3. USB Different USB interfaces are provided in the G05 depending on the vehicle equipment. USB interfaces: • Type A in the center console. • Type C in the center armrest. • Type C charging only 2 x in the backrests. • Type C 2 x in the Rear Seat Entertainment control panel (from 11/18). A charge current of max. 1.5 A is available via the USB port in the center console. A charge current of max. 3 A is available via the USB port in the center armrest and via all the other USB ports in the rear passenger compartment. Ports do not support PD.
thereef5101169.00 omasou2093.00 |
01-09-2019, 10:52 AM | #5 | |
Rep 420
BTW, I have the Executive Tier which includes the enhanced USB and Bluetooth, not sure if that affects the voltage or not. salfeet84 - thank you for the recommendation, I'll look into the device but I was hoping to not clutter the new car Last edited by wdlv; 01-09-2019 at 10:56 AM.. Reason: Adding information |
salfeet84309.00 |
01-09-2019, 11:42 AM | #6 | ||
Rep 579
01-09-2019, 01:05 PM | #7 |
Rep 129
I have the executive package and I bought a USB type C to A converter to charge the iPad. I didn't see any low voltage message and they charged just fine. I did not check the charge rate though.
01-09-2019, 01:18 PM | #8 |
Rep 5,350
The voltage message can be fussy with various devices. That doesn’t mean it won’t charge fine.
My kids iPad Air 2 and Lenovo Tab a charges fine from the back seat charger. I use adapter plugs purchased from Amazon for the USB C. |
01-09-2019, 01:20 PM | #9 |
Rep 6,121
Drives: 2022 Porsche Boxster GTS
Should he 5V/3A max depending on what port. I have a USB C multimeter but no X5 yet due to delays. I could stop by my local dealer and test one if someone wants
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
01-09-2019, 02:34 PM | #10 |
Rep 134
I tried mine with Samsung s9+ and in all doors I get slow charging. All. In the back also.
Only option for fast charging is if connected to lighter connector with a fast adapter |
01-09-2019, 02:44 PM | #11 |
Rep 6,121
I have a S9+ too, let me see if my local dealer has any and I'll test the current draw with my USB C meter.
MystroX56320.50 |
01-09-2019, 05:46 PM | #13 |
Rep 6,121
5A? No, it depends on the charging spec of the device in question. I wish they used USB C PD but I doubt it. I'll have to verify at some point but there are different specs. Fast charging is usually done at 9V/12V/20V over USB C PD but can also be done at 5V. The higher voltage means less heat for the same power output. 5V/2A generates more heat than 9V/2A for example. I have no idea what BMW is using so we will see. 5 Amps or 5A is way too much to do in a car over USB C unless they're using power delivery at 20V ,5A isn't really a charging spec
01-09-2019, 06:38 PM | #14 |
Rep 5,350
01-09-2019, 06:41 PM | #15 |
Rep 420
01-09-2019, 07:14 PM | #16 | ||
Rep 6,121
01-10-2019, 09:13 AM | #17 |
Rep 7
The voltage of USB interfaces is specified by the USB standard, not BMW. Given that the ports don't support Power Delivery, the output voltage will be capped at 5V. Power Delivery is a standard that allows devices connected to the port to negotiate with the power supply to switch to a higher voltage; without negotiation that standard states that an initial voltage of 5V must be used. Unless some kind of proprietary standard is used (Qualcomm used to have its own QuickCharge protocol, but seems to be phased out in favor of Power Delivery), 5V is what the port will provide. But I doubt BMW would implement any proprietary protocol in its USB ports anyway.
As specified in the technical documents, the maximum current allowed through the USB ports is 3A. Some USB-C-to-A adapters may limit the current being passed through them, especially if that adapter was designed for the USB 3.0 protocol. USB 3.x protocols have a default current of only 0.9A. |
AndroidRobot4336.00 |
01-10-2019, 10:48 AM | #18 | |
Rep 6,121
10-14-2021, 03:45 PM | #20 |
Rep 1,771
Does anyone know how long do USB ports as well as front and back 12V ports stay active after car is locked/walked away with comfort access? I plugged a light the other day working on the back, I tested it and walked away came back about 3-4 minutes later, light was still on. Do they not shut off eventually?
2024 X3 m40i
10-14-2021, 04:48 PM | #22 | |
Rep 1,771
I searched for "several minutes" and never thought I should look for "Idle State". Automatic idle state The idle state is automatically established under the following conditions: Operating state of the vehicle ▷ After several minutes, if no operation takes place on the vehicle. ▷ If the charge state of the vehicle battery is low. ▷ Depending on the setting via iDrive, if one of the front doors is opened when exiting the vehicle. It also somehow says we can do it manually by: Manual idle state To establish idle state in the vehicle after end of trip: Press and hold the button until the OFF indicator on the instrument cluster goes out. Idle state Concept When the vehicle is in idle state, it is switched off. All power consumers are deactivated. General information The vehicle is in idle state prior to opening from the outside and after exiting and locking.
2024 X3 m40i
