01-15-2019, 08:59 AM | #1 |
Rep 57
Brembo front calipers for my f32....
Hello everyone.
I just bought a pair of Brembo M performance FRONT calipers (the blue ones) for my F32 that I want to install by next week. As shown in the picture my f32 came with the grey unpainted front Brembo calipers. My question is: Do I need to change the front rotors? Do I need to make any modification? Or just switch the calipers? I believe for these M blue brembos I need the 370mm rotors, but both brembo calipers (the blue ones and the grey stock) look pretty similar to me. Any information is greatly appreciated! Thanks! Last edited by Miami305; 01-15-2019 at 11:00 AM.. |
01-15-2019, 11:27 AM | #2 |
Rep 402
Drives: F87 M2C
Yes the blue ones need 370mm rotors and the grey ones need 340mm rotors.
The blue caliper mount is slightly extended compared to the grey one.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
kern4174464.00 |
01-15-2019, 12:50 PM | #3 |
Rep 1,934
Look on the back of the blue calipers because they also came in a 340mm variant which wouldn't need a new rotor. There's always a marking on them to dictate which carrier/rotor it uses.
Also, you should probably do this kind of research before you purchase parts.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
Pittcrew34.00 |
01-15-2019, 02:32 PM | #4 | |
Rep 402
Drives: F87 M2C
This one should say 370/380 actually but as far as I know would only work with the 370mm on none M cars.
01-15-2019, 03:05 PM | #5 | ||
Rep 1,934
01-15-2019, 04:16 PM | #6 | |
Rep 402
Drives: F87 M2C
So all in all, OP should get 370mm rotors.
01-17-2019, 10:54 PM | #9 |
Rep 1,934
Correct
01-29-2019, 03:33 PM | #10 | |
Rep 1,071
I'm currently looking at the possibility of purchasing a set of blue F80 front+rear calipers. Does this mean I'd need 380mm or 370mm rotors for my F32? I'm unsure what dictates the sizing difference - is it the mount? |
01-29-2019, 03:55 PM | #11 | |
Rep 402
Drives: F87 M2C
The actual Knuckle/Carrier that the entire caliper mounts to is different between M Cars and ours.
louielouie552.00 |
01-29-2019, 04:42 PM | #12 |
Rep 1,071
