Dead-horse: necessity of index 12s for tuning?
01-18-2019, 08:23 AM | #1 |
Rep 80
I've got a mixed bag of injectors: 6,8,9 indexes, ~2 of each. I know the 9s are of I'll reputation, but, the car runs well otherwise. Consensus seems to be a perfunctory change up to index 12s, but I'm curious as to the actual risks of popping my motor with a tune and older injectors ?
If one of my injectors fails by leaking, I can handle that. If it fails at WOT by going super lean, that I cannot. I guess what I'm asking is how common it is for injectors of those indexes to fail catastrophically? I've used the search function, but there are a lot of parrot posts without any explanation aside from "just do it". Thanks! -Cm |
01-18-2019, 11:41 AM | #2 |
Major Private First Class
450
Rep 1,327
Drives: 2010 E90 335i M Sport
There is no inherent risk of popping the motor with older ones. I would change them as needed. Injectors fail at random. Even index 12 injectors have failed before. Ideally, you run the latest because it has the least "shelf life" and they MAY have some kind of design change to improve the internals (just a solenoid really).
Only thing you need to consider is that if you swap in an index 12 in bank 1 (cylinders 1-3), the remaining injectors in that bank need to be 11 or 12 as well. Same goes with bank 2. Are the injectors you described new?
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
01-18-2019, 07:00 PM | #3 |
Rep 80
Thank you for your thorough reply! I have no idea how old they are in years or in miles. I bought 'er at 90k, up to 97k now. Lots of dealer maintenance records, but they just say "fuel system service" on the carfax.
It does, every once in a while hiccup when it's cold. Carbon cleaning was apparently done recently. -Cm |
01-18-2019, 08:35 PM | #4 |
Rep 115
These injectors won't fail catastrophically. You will be able to see the symptoms well before it gets to a point of actual danger to your engine. mine would spit gas out of the exhaust on cold starts and ended up staining my driveway. as well as running rich and fuel smell, you will be able to see the symptoms I'm sure.
I would say put the 12's on the back burner unless you have the budget or love proactive maintenance. |
01-18-2019, 11:10 PM | #5 |
Rep 1,532
Nah, just be ready to replace them if/when you see they're misbehaving. As long as logs look good, car starts/idles/decels fine without any signs of leaking (a/f doesn't immediately go to max on decel), I'd keep running them for a while.
01-19-2019, 03:18 AM | #7 | |
Rep 1,827
01-20-2019, 02:30 AM | #9 | |
450
Rep 1,327
https://www.e90post.com/forums/showthread.php?t=1417068
01-20-2019, 05:15 AM | #10 | |
Rep 3,730
With that said, I’m tuned and running on index 9s and so far so good. Will update to index 12 once they start misbehaving. I’d also check whether you fall under the Bmw extended warranty for fuel injectors so you don’t have to pay out of pocket. See SIB 010215 |
01-20-2019, 10:58 AM | #12 |
Rep 1,946
