BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos M3 GTR
      07-18-2008, 11:00 PM   #1
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
M3 GTR
nothing new but some info on the car
The E92-based successor to the E46 BMW M3 GTR from 2001 has been unveiled, and it marks BMW’s return to the American Le Mans Series. The new BMW M3 Race Edition is a highly specialized version of the E92 M3 built to tour the ALMS in 2009. It will be used by Rahal Letterman Racing, predominately owned by racing legend Bobby Rahal and American comedian David Letterman.
The new BMW M3 Race Edition’s P65 V8 engine produces 485 horsepower and 500Nm of torque, up from the standard M3’s 414 horsepower and 400Nm of torque.
Technical Specifications BMW M3 Race Version
Weight: 2,535 lbs./1150 kg
Tank capacity: 29 gallons/110 Liters
Chassis/body: Unitary construction steel body with welded safety cell made of extremely rigid precision steel tubing; safety fuel tank in CRP sandwich tray; pneumatic four-stamp jack system
Aerodynamics: Front fenders, rear apron, hood, roof, trunk lid, rear wing, front wings, and flared rear wheel arches in CRP
Transmission: Carbon fiber clutch with hydraulic central slave cylinder; 6-speed sequential racing transmission with straight-cut, unsynchronized gears; additional oil/air cooler; quick shift system with ignition cut-out controlled by shifting force; mechanical limited slip differential with additional oil/air cooler
Front axle: Based on production version, with increased wheel caster angle, enlarged track width and enhanced wheel camber; five-way adjustable shock absorbers; tubular stabilizer bar
Rear axle: Based on production version, with enlarged track width and enhanced wheel camber; five-way adjustable shock absorbers, tubular stabilizer bar
Front brake system: Six-piston aluminum brake calipers, inner-vented grey-cast iron brake disks 15.0 in./380mm in diameter
Rear brake system: Four-piston aluminum brake calipers, grey-cast iron brake disk, 13.1 in./332mm in diameter
Steering: Rack and pinion steering with electro-hydraulic power
Wheels: Aluminum wheels, 18 inches
BMW P65 Engine
Type: Eight cylinder, V-configuration
Capacity: 3999 cc
Bore x stroke: 92 x 75.2 mm/3.62 x 2.96 in.
Max. output: approx. 485 bhp
Max. torque: approx. 368 lb-ft/500 Nm
Cylinder block: Aluminum cylinder block construction with bed plate lower section
Crankshaft: Steel crankshaft
Pistons: Forged skirt pistons
Conrods: High-performance steel
Cylinder head: Aluminum DOHC (Double Over Head Camshaft); four valves per cylinder
Valve train: Four overhead chain-driven camshafts, valve actuation via rocker arms
Intake system: Eight throttle valves, made of CRP with load-charge optimized ram tubes
Exhaust system: Headers, mufflers
Fuel system: Single cylinder multi-point injection
Lubrication: Dry sump lubrication
Cooling: Water/air cooler and oil/water heat exchanger
Electrics/Electronics
Engine management: BMW Motorsport ECU 408 with two high-performance micro-processors; Individual cylinder injection and ignition; BMW Motorsport Lambda Controller Pit speed limiter, Quick Shift function; Engine data memory system
Energy management: Electric energy management and monitoring with BMW Motorsport POWER400 control unit, networking of all sensors and actuators through bus system
Wiring harness: Weight optimized
Ignition coil: Eight high-performance pencil coils with integrated ignition drivers
Spark plugs: High-performance spark plugs
Cockpit: Free programmable LCD Display with integrated shift indicators
Steering wheel: Quick release multi-function steering wheel w/ integrated display unit
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      07-19-2008, 12:17 AM   #2
Davin
Davin's Avatar
Trinidad_and_tobago
61
Drives: Yes
wouldn't mind doing up my future E92 like that
      07-19-2008, 12:45 AM   #3
M3MIKE
M3MIKE's Avatar
Drives: 2008 M3 COUPE
http://www.worldcarfans.com/9080714....onto-the-track
      07-19-2008, 12:50 AM   #4
BayAreaE92
BayAreaE92's Avatar
23
Drives: 91' 850i
1991 850i  [7.75]
2007 328i Coupe  [0.00]
SOOOOOO RAWWW
Here's some pics I took during the Festival of Speed Weekend @ Laguna Seca
      07-19-2008, 02:00 PM   #5
Year's_End
Year's_End's Avatar
Drives: 2020 Shelby GT350
That car is amazing in so many ways, and I actually like how it looks now with the blacked-out front bumper (not displayed here).
And I would kill for those wheels. Best damn wheels I've seen in a long time.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      07-19-2008, 02:12 PM   #6
ALPINE6SPD
ALPINE6SPD's Avatar
Drives: 2010 BMW 328i Sport
Sinister looking
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills
2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone
2008 AW X3 3.0si: 6 speed Returned
2006 AW e90 330i: 6 speed Dinan Stage 1 Returned
      07-19-2008, 02:45 PM   #7
darkphantom
Drives: E93 335i
saw a vid - SICK.
check out the episode for the M3 DTM
www.vodcars.com
