Blower motor Recall
01-23-2019, 08:20 AM | #1 |
Rep 684
Drives: 09 328i Sport 6MT
Blower motor Recall
Recall was done about a month ago.
Am I wrong in thinking my fan/blower motor should be new? It's still squeaking and creaking when it's cold....was that not supposed to be changed out? |
01-23-2019, 08:27 AM | #2 |
Rep 1,100
When recalls are performed, the dealer will always use new parts. Are you sure the fan/blower motor is squeaking and not another component?
01-23-2019, 08:39 AM | #4 |
Rep 14,829
the motor was not a standard part replaced, looked to me like a tech would splice some new harness in. imho? splicing is unfortunate, it's a new weak point, subject to human error, unlike plugs.
Antetokounmpo1551.50 |
01-23-2019, 08:47 AM | #5 | |
Rep 684
Also have a high pitched/ high speed ticking sound that changes with revs...maybe alternator? Why is it that things break right after going to dealer... |
01-23-2019, 08:52 AM | #6 | |
Rep 1,100
John makes a good point above. If the recall is for the wiring harness and not the motor itself it could be that the motor itself failed coincidentally after the recall was performed. Do you guys have the campaign number for this recall? |
01-23-2019, 08:58 AM | #7 |
Rep 2,835
Blower motor wiring recall was for the wiring ONLY.... not the motor.
The recall was updated to also replace the regulator. https://static.nhtsa.gov/odi/rcl/201...7V676-3259.pdf |
apexit41230.50 Antetokounmpo1551.50 |
01-23-2019, 08:58 AM | #8 |
Rep 596
My blower motor totally stopped working in the dead heat of summer; I popped out the underside panel and also noticed some spotting/corrosion around the harness end. Dealership ended up replacing the entire harness (not spliced), blower resistor/regulator, and the actual blower fan at their cost per recall.
You could bring it up to your service advisor, but given it's been about a month already, you may be out of luck. "Doesn't hurt to ask"...good luck.
2007 BMW 335i, 2014 Audi A4, 2016 Acura MDX
Join us on Facebook: E90Post - Houston Houston BMW DIY Services |
01-23-2019, 12:29 PM | #9 |
Rep 1,309
Mine used to squeak, then the blower stopped working entirely as well.
I was worried it had failed because of the harness, so I pushed the dealer to move up my car in the recall list (it was still flagged as parts not available). My dealer spliced in a new harness, called me to ask if I wanted to pay them $400 to replace the blower motor, and when I said no, they added a little oil to the bearing and worked it in a bit. It started squeaking again about a month later, and still does. |
01-23-2019, 02:26 PM | #10 |
Rep 2,835
My blower motor started squeaking fairly significantly after the recall was done.
I just picked up a used one from a recycler who had a 2015 X1 that only had 20k miles on it... gave $50 for it. |
01-23-2019, 05:20 PM | #12 |
Rep 2,835
Used even later than that....
01-23-2019, 07:02 PM | #13 |
Rep 1,309
There's a late F25 X3 at my yard that I've pulled a bunch of parts from...
buuut... it had an engine fire. wonder if the blower is a) good, and b) not covered with soot. |
01-23-2019, 07:45 PM | #14 |
Rep 2,835
