01-23-2019, 06:29 PM | #1 |
Rep 24
Got my VRSF CP and FMIC today
So just received my vrsf CP (xdrive) and (5" HD) Intercooler today and wanted to post pics since all i see are bashing posts and as far as i can tell (which i can't because i'm not an expert) everything looks a-ok. The tabs on the intercooler look a little long though like that one thread was saying, but I'll attempt to install it this weekend and take more pictures then to see if everything installs ok.
I'll just post the link to the imgur gallery instead of posting the pictures here. View post on imgur.com |
01-23-2019, 08:15 PM | #2 |
Rep 832
Drives: 2019 G01 X3
Looking forward to seeing how the install goes!
01-23-2019, 09:12 PM | #3 |
BimmerPost Supporting Vendor
24442
Rep 191,344
Congrats!!
Please post pictures of the products
01-23-2019, 09:59 PM | #4 |
Rep 24
01-24-2019, 10:00 AM | #5 |
24442
Rep 191,344
Thank you
01-28-2019, 02:21 PM | #6 | |
Rep 2,661
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
01-28-2019, 06:43 PM | #8 | |
Rep 24
https://www.lowes.com/pd/SpeedOut-8-...tor/1000170531 The charge pipe was a damn pita though. Not sure if it's cause it's xdrive auto. I spent a good couple hours trying to get it seated onto the throttle body. I used oil and force and clamps a blowtorch, finally it went on. The tmap sensor wouldn't go in with the gasket, I oiled that as well and pushed and it took some of the gasket off (it seems to be holding a seal though but i'll need to replace it and try again). Then i tried to reattach the fuel tank vent line but that wouldn't go in either and shattered and broke off (i pushed too hard). Had to reorder that for 90 bux. So the FMIC is fine, the tabs were a little long but it still "fit" If i can't get the new fuel tank vent line to go in, i'm going to buy a different charge pipe. I'm going to try to heat it up and lube the crap out of it and try to shove it in a little more carefully than last time. I need to take it out on the freeway or find a long empty road to log on, but didn't really finish installing in time. I'll post when i get a chance to do so. Edit: i tried to rig up something with the fuel tank vent line but still getting a fuel vent valve error so i just capped it off at the chargepipe for now (giving the stuck open error). It doesn't' seem to be affecting performance though as far as i can tell. New tubing will be coming on Friday. Last edited by rtsea; 01-28-2019 at 07:01 PM.. |
01-28-2019, 07:10 PM | #9 | ||
Rep 2,661
01-28-2019, 07:14 PM | #10 |
Rep 24
Sure I can do that I think, after rush hour tonight (PST) i'll take it out on the freeway. I don't have the MHD monitor but i'll buy that now. It'll be my first time logging so I may f' it up. But hopefully will have something posted here tonight. I've been meaning to do it anyhow to see if i have any boost leaks from my less than perfect install.
01-28-2019, 07:48 PM | #11 |
A family of bimmers
2757
Rep 7,743
I feel like I'm the only one who didn't have that much trouble putting on the chargepipe at the throttle body. Maybe it's because my car was warm when I did it and slid right on. Tmap was a tight fit but went on as well without issue.
Quality of the parts look way better than what I got from them a year ago. That's a great improvement to see. Tabs being a little long appear to be because it sits slightly lower than stock. I've been running with the wrong tabs a year and it hasn't been an issue. Glad they fixed it for others going forward.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
01-28-2019, 07:57 PM | #12 | |
Rep 24
01-28-2019, 08:58 PM | #13 |
Rep 24
So i did a fast run in the little space i could with all the traffic right now. I'm not sure how to read it completely yet so feel free to point out anything that looks strange. The temperature outside is 37.
https://datazap.me/u/rtsea/log-15487...=3-4-5-6-13-15 |
01-29-2019, 09:53 AM | #15 | |
Rep 2,661
02-02-2019, 12:12 PM | #16 |
Rep 24
I got the fuel tank vent line today, Tip for other people, drive around get your car warmed up and then disconnect the vent lines from the other two connection points before trying to push it into the charge pipe (this is how i broke it originally by not disconnecting it). I sprayed it with a little silicone lube (probably should have used some grease) and pushed and twisted it back and forth and it went in (with some effort). I've got to do the tmap gasket later today.
02-02-2019, 01:21 PM | #17 |
Rep 24
Got a new datazap 3rd gear run. looks like it's down to around 1psi boost/target difference. IATs are still nice with the 5" vrsf hd. wgdc% looks a bit high though (i think i'm not sure if it's supposed to be that high on stock turbo ewg). I'm on mhd stage 2 right now.
https://datazap.me/u/rtsea/log-15491...3.00&tmax=3.00 |
02-02-2019, 03:31 PM | #18 |
Rep 24
think i found the culprit for the leak lol.
anyhow another tip from a non mechanically include DIYer. the screws (allen head) that come with the vrsf pipe for the tmap sensor suck and get stripped easily (or i just can't hold the allen key straight enough). I bought these phillip head ones to replace them and they fit perfectly and were easy to tighten. Incase the images don't show up the links are View post on imgur.com and View post on imgur.com |
02-02-2019, 05:13 PM | #19 |
Rep 24
The intercooler is doing awesome though, here's a log of my last (of 6) 4th gear runs. ambient temp is 47.
https://datazap.me/u/rtsea/log-15491...=3-4-5-6-13-24 |
02-04-2019, 01:04 PM | #20 | |
4927
Rep 116,034
Mike |
