02-08-2019, 10:49 PM | #3 |
Rep 293
02-09-2019, 08:48 AM | #5 |
Rep 16,199
I didn't see anything about the sensors to draw that conclusion. Doing it myself I wouldn't bother to change it, knowing if it does go south on me I can pull the wheel and replace it in fifteen minutes. If you're not doing your own brake work the cost of having someone else replace it is probably four times the cost of the sensor, so you might as well have it replaced along with the pads.
02-14-2019, 11:35 AM | #7 |
NewFinishColumbia/detailer
604
Rep 2,096
It's an electronic measurement device. Just replace them when you replace the pads for that end of the car. If you stay aware of your maintenance you don't really need them because you will notice when your pads are getting low and need to be replaced. And it's one per axle. I made the mistake of buying twice as many because I though each corner was measured independently. Now I have spares.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
