02-13-2019, 07:05 PM | #1 |
Rep 6,121
Drives: 2022 Porsche Boxster GTS
Post your Draggy or otherwise recorded 0-60mph (0-100kmh) and 1/4 mile times here.
I did a 0-60 earlier but no launch control, DSC off, Sport+. The car didn't shift as fast from 1st to 2nd which was odd. I also had my spare tire in the trunk and some groceries so that surely didn't help! I'll run some more with better conditions because I know it'll do sub 4.3s 0-60 stock. Please add DA data too for reference edit: picture won't attach right now, I'll add it later. Until I add the pics recorded 0-60 (very bad run) 4.48s
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
02-13-2019, 07:16 PM | #2 |
Rep 668
I took a video of the cluster while doing an acceleration test (on a closed course ) and using launch control and sport mode. Using video editing software, I've estimated it went 0-60 in 5.2s. This is a 40i.
02-13-2019, 07:44 PM | #3 |
Rep 282
02-13-2019, 10:21 PM | #4 | |
Rep 6,121
you can see the big g force change when it finally shifted. comparing my times to yours by section that's what made things slower I was running 91 octane 1/2 tank (we don't really have 93 octane here)
02-14-2019, 06:13 AM | #7 |
Rep 6,121
Draggy, it requires their sensor which uses GPS and an accelerometer (for G forces)
One press of the traction button put the car in sport+, gear lever in S, left foot on brake firmly, right foot floored on the gas, launch control message pops up release the brake and go
Num3erz2.50 |
02-14-2019, 06:58 AM | #8 |
Rep 668
One thing to keep in mind is that launch control will only activate if the vehicle has been driven a few miles since starting the engine (5 or 6 I think?). I don't think it matters if it's already warm either. One time I had driven for two hours, stopped for gas, and then tried launch control right after leaving the gas station and it didn't work.
02-14-2019, 06:59 AM | #9 | |
Rep 6,121
02-14-2019, 07:17 AM | #12 |
Hammer
203
Rep 202
Think you may be correct. Saw both numbers reported early on.
2019 BMW X5 40i
2014 MB E63 AMG |
02-14-2019, 07:36 AM | #14 | ||
Rep 282
02-14-2019, 07:51 AM | #15 | |||
Rep 6,121
The X5 simply doesn't shift as fast as my X3 M40i did even in manual mode
02-14-2019, 07:53 AM | #16 | |||
Rep 6,121
02-14-2019, 08:57 AM | #17 |
Rep 282
Posting a great time requires a fair amount of luck since there are so many factors involved. If you think about it, 0.1 or 0.2 seconds is such a minuscule period of time that one little thing here or there can be the difference between a 4.4 and 4.2.
02-14-2019, 09:02 AM | #18 |
Rep 6,121
Yes and no, even with a lot of luck and testing even my M50i would only post 4.4s at best but I think I need a proper surface for better grip too
02-14-2019, 09:09 AM | #19 |
Rep 5,356
How much gas in your tank? In my experience, that can make a huge difference. On a side note, I worked with my neighbor with his new Z51 to get a decent time. That was like pulling teeth. He had to work to get a real world 0-60mph under 5 seconds. All kinds of issues with hooking up, and shift rates. It wasn’t a easy car to get to go fast from a stop. His RS3 would crush his Z51 in 0-60mph. Just look at how hard a Hellcat is to get a respectable real world 0-60mph.
02-14-2019, 09:12 AM | #20 |
Rep 6,121
1/3 right now, removed the spare tire, ran a 4.47s 0-60 earlier this morning after warming up the tires. We only have 91 octane though for the record
02-14-2019, 09:21 AM | #21 |
Rep 5,356
That will make a difference. We run 93 to Sunoco 94 Ultra. My C4S loves the 94 octane. What was your outside temp and humidity rate when you did your morning run? Was your climate control completely off? Add a extra 5lbs of pressure to your tires. You wouldn’t believe what Mopar does to get their times.
02-14-2019, 09:34 AM | #22 | |
Rep 6,121
Here's the DA data for this morning: Later today when it's 80F the air density will go down to 85% so that won't help
