02-15-2019, 03:46 PM | #1 |
Rep 28
F36 435i strut bar options
Hello,
I can't seem to find a strut bar for the 435i gran coupe that would fit over the engine with the engine cover on. Could anyone give me a summary on what are my strut bar options for this car? |
02-15-2019, 04:15 PM | #3 | |
Rep 340
2016 435i GC - FBO - PS2 - XDI-35 hpfp - Stage 2 lpfp - M performance LSD -Custom tune BM3 w/ MHD monitor - xHP Flash stage 3 - Valvetronic Design Exhaust
02-15-2019, 04:22 PM | #4 |
Rep 1,934
A strut bar for any of the F3x (N55) cars will fit. The KC above is a great option, Turner has aluminum and cf options. I've seen Megan Racing, Ultra Racing as well.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
02-15-2019, 07:58 PM | #5 |
Rep 1,030
Drives: 2019 440xi Gran Coupe
What’s the price? I can’t read chinese
02-15-2019, 09:26 PM | #6 |
Rep 340
i paid $175 shipped.
02-15-2019, 09:28 PM | #7 |
Rep 340
not really the tuner and seibon strutbar didnt fit because it for the 2015 and older.. starting 2016 they change the strut bolt into a 5 bolt configuration.
Logicoeur993.50 |
02-16-2019, 11:25 AM | #8 |
Rep 603
I installed the strut bar from Wiechers.
https://www.wiechers-sport.de/en/sho...rkstreben/info However the F36 is not listed, but just contact them. Wiechers is a very well known brand in Europe for those kind of mods. Don't know if they ship to the US, but just ask.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
1QuikWS61623.00 |
02-24-2019, 09:11 AM | #9 |
Rep 28
All right, it seems that KC design is the one i would go for.
But here is another question: does it make a difference, and is it worth it? Most BMWs have a strut bar integrated into the bodywork (there is a piece connecting the two struts, not sure if it is rigid though), so how much difference does this 'extra' strut bar make? |
02-26-2019, 01:30 PM | #10 |
Rep 8,524
My reply on the "Strut Bar" thread :
I fitted a strut brace to my F31 330D as the 'last' suspension mod, and I can't say I've noticed any difference. What do you want to achieve ? If you're looking for improved steering precision and control I strongly recommend having the OEM compliance bushes in the lower control arms replaced with SuperPro camber adjustable poly bushes. It's a relatively cheap mod and the improvements, including being able to achieve more negative camber, are definitely worth it. FWIW I have the Weichers unit (it came off an F31 335D) and it clears the engine cover and the underside of the bonnet (hood). Clearance between the strut brace and the engine cover is quite tight in places, and I've had to resort to self-adhesive felt pads to eliminate annoying buzzing noises from the engine bay at different engine revs.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
02-26-2019, 10:58 PM | #11 |
Rep 3,549
That's interesting you didn't notice much Watsey. I've been very happy with my front bar purchase and noticed a significantly tighter feeling front end, particularly noticeable in higher speed cornering. I also noticed some improvement in steering feel (in comfort mode that is, for some reason the sport mode steering is more numb than comfort). The rear bar I got didn't have any noticeable improvement though.
02-27-2019, 01:45 PM | #12 |
Rep 8,524
FaRKle! Yeah I can't say I noticed anything significant. That said, the suspension and bushing on the front of my car was already pretty well sorted so my expectations were that the gains were always going to be into the realms of diminishing returns.
That said, with the front suspension turrets already braced back to the bulkhead (OEM) it can only be a good thing to complete the triangulation of the front suspension mountings.
12-19-2020, 03:00 PM | #13 | |
Rep 724
