Just got a walnut blast done, will adding an oil catch can prevent buildup at all?
02-18-2019, 07:14 PM | #1 |
Rep 541
Simple question, walnut blast is recommended every 50k ... if I install a catch can, will that slow buildup in anyway?
Meaning is there any way at all that 70k with a catch can would like like 50k without a catch can for example? |
02-18-2019, 07:36 PM | #2 |
Rep 3,730
Only if you run dual catch cans and plug the head.
Look at BMS for high side and mishimoto / rb turbo external pcv for low side.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
02-18-2019, 07:44 PM | #3 | |
Rep 541
I was planning on mishimoto, and then I’ve heard about the RB PCV valve, so how do they actually run together? How does the flow actually change? Does the RB valve not allow oil down a certain path? And then the catch can contains the flow? |
02-19-2019, 08:07 AM | #4 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
build up in inevitable with a DI only engine. It will just delay it a bit.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
02-19-2019, 09:06 AM | #5 |
Rep 1,643
Definitely get the rb style pcv valve.
You may be better off just using the money you'd spend on a catch can for another walnut blast - doesn't catch much.
2007 E92 335i MT
02-19-2019, 10:27 AM | #6 |
Rep 175
You really need to do the rb modification which includes removing the valve cover and tapping some holes. If you aren't comfortable doing this then I wouldn't bother with catch cans.
02-20-2019, 09:23 AM | #8 |
Rep 541
02-20-2019, 09:30 AM | #9 |
Rep 50
I have a burger catch can and an RB pcv valve. I pulled my intake off last week after a year since and its just as clean now as it was right after it was cleaned. I always have tons of oil in my catch can, but none in my intake anymore.
The_Werm214.00 |
02-20-2019, 09:36 AM | #10 | |
Rep 1,946
I have no say on the valves yet but would imagine they still get some build up without the head ports being plugged. |
02-20-2019, 12:53 PM | #11 |
Rep 22
How often do you clean out your catch can ?
02-20-2019, 12:54 PM | #12 |
Rep 22
If you don't mind me asking how much did your walnut blast cost you ?
02-20-2019, 01:53 PM | #14 |
Rep 22
02-21-2019, 09:41 AM | #17 | |
Rep 186
That's also why you can buy a car in a small rural state and sell it in Miami or California for more money. Mike |
02-22-2019, 06:57 AM | #20 |
Rep 50
03-09-2019, 09:20 PM | #21 | ||
Rep 22
03-13-2019, 11:54 AM | #22 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
I plan on doing another walnut blasting this spring. I will post pictures etc., of the intake valves prior to cleaning them. |
