02-18-2019, 07:37 PM | #1 |
Hoxsie16
Rep 10
Throttle Body Needs To Be Replaced
Wondering if anyone else has had this issue. I have a 2017 M240i 6Mt with only 8700 miles on it. The other day the check engine light came on a day after getting gas. I thought that it might have something to do with that, but when I brought it in to the dealer it was diagnosed as a bad throttle body and they had to order the part. Though it is being done under warranty, I wonder if anyone else has had this problem.
02-19-2019, 11:14 AM | #2 | |
Rep 823
02-19-2019, 12:10 PM | #3 |
Hoxsie16
Rep 10
The service advisor said it was the throttle body and they would have to order it. He tried to tell me that it could have had something to do with filling up with gas without shutting off the car which sounded like BS to me. I have done that for years with my Infiniti G37.
02-19-2019, 12:11 PM | #4 |
Rep 5,394
This isn't a common issue on the B58 or N55 motors.
Just an FYI, the B58 and N55 use valve lift and timing (Valvtronic) to take the place of throttle control in almost all situations. Only in certain situations does the DME (engine computer) use the throttle body. Those situations would include an uncontrolled over-boost situation, excessive detonation, or Valvetronic failure.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
overcoil3081.00 |
02-19-2019, 05:18 PM | #5 |
Hoxsie16
Rep 10
Thanks for the info. It makes me wonder if the service advisor wasn't being truthful with me about the issue. Do you think that it might be a VANOS issue? I know on the B58 it requires an engine drop since they are located at the back. I asked the advisor if the work required an engine drop and he definitely said "no", but as I said I now question his truthfulness.
02-19-2019, 07:07 PM | #6 | |
Rep 326
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also" |
makrop151.00 |
02-20-2019, 01:09 AM | #8 |
Rep 366
Drives: 218i Coupe
Garage List 2020 BMW X2 [5.25]
1993 BMW 850Ci [8.33] 1990 BMW 316i [8.00] 1994 BMW 318i [0.00] 2000 BMW Z3 Coupe [8.83] 1974 BMW Alpina A2 ... [10.00] 1985 BMW 635 CSi [0.00] 2018 BMW X3 [0.00] 1975 BMW 2002 [5.50] 2016 BMW 218i Coupe [8.00] 2006 BMW Z4 M Coupe [8.67] |
Plus might be illegal depending where you live. Also dangerous for you and others at the station.
02-20-2019, 01:11 AM | #9 |
Rep 555
Why would you leave the car running while pumping? As pointed out, it is also illegal in quite a few states. Like i dont underatand the reasoning for this...
02-20-2019, 09:52 AM | #10 |
Hoxsie16
Rep 10
To answer the useless comments, I live in an extremely hot and humid climate and the interior of the car gets very uncomfortable for the passengers in a very short time. Perhaps if you have nothing useful to say about the issue, you should consider keeping your unuseful comments to yourself.
02-20-2019, 10:09 AM | #11 |
Rep 296
A. Dont be an asshole.
B. Its extremely STUPID to fill your car up with the engine running. C. The repair is getting completed under warranty by the dealer. When they are done with the work look at the repair order and it will list all parts and labor performed. They wont "lie" about that. Its quite possible your service adviser is generalizing and just giving you a explanation that he understands how to explain. |
02-20-2019, 11:25 AM | #12 | |
Rep 326
B) Thanks for the explanation, I figured it was something like that. C) Sorry about the "useless comment ", but IT IS the internet. D) Changing my username to "Useless Comment"
02-20-2019, 11:43 AM | #15 |
Rep 5,394
You really should not fill up your car while it is running ESPECIALLY with people in the car. Seriously, don't do it. It's also very likely illegal in FL as it is in most any state. If people are hot sitting in the car, then roll down the windows. The heat in FL isn't that oppressive that someone can't sit in a car for 2 minutes with the windows down.
02-20-2019, 07:39 PM | #16 |
Hoxsie16
Rep 10
Picked up the car today. They ran several tests, including smoke test on the intake system (no leaks), no leaks in the throttle pipe, and did a throttle test which showed slow movement when activating.
They replaced the entire throttle housing assembly (part 13-54-8-601-651, MSRP $641) under warranty. Seems fine now, but I still can't understand how this part fails with only 8700 miles on the car. Thank you all for your input. |
02-20-2019, 07:48 PM | #17 | |
Rep 5,580
02-21-2019, 01:12 PM | #18 |
Rep 1,220
Drives: 2015 M235ix
In most jurisdictions, it is illegal to fuel a vehicle with the engine running, for the simple reason that there is a good possibility that the vehicle will explode, along with you and everything in the vicinity, if you set off a static spark.
DON'T DO IT! |
