02-22-2019, 12:45 PM | #1 |
Rep 121
Fault code showed up today!
I have a jb4 catless downpipe intake and mpe.
This code showed up today. Anybody have an idea?
Instagram: 709m240i
02-22-2019, 02:48 PM | #2 |
Rep 5,394
That last code is alarming. Are you low on oil? I would not drive the car hard at all if oil pressure is too low. That's something that definitely needs to get checked out.
Is you check engine light on? If so, what is the car telling you to do?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
02-23-2019, 08:44 AM | #3 |
Rep 121
Check engine came on but car never told me to do anything. Oil level is fine
Instagram: 709m240i
02-23-2019, 09:16 AM | #4 |
Rep 1,117
Drives: 2015 BMW M235i
oil pressure is a huge deal. Definitely do not drive it. Does jb4 have a oil pressure monitor?
02-23-2019, 11:30 AM | #5 | |
Rep 121
I was just cruising on the highway after startup when it came on along with the code because of my catless dp. It's was about -40 degrees Celsius that morning so not sure if that has anything to do with it. Been driving the car since with no issues.
Instagram: 709m240i
02-23-2019, 01:09 PM | #6 | ||
Rep 1,117
02-23-2019, 01:46 PM | #7 | |||
Rep 121
Last few days has been extremely cold. I've been driving fine for about 60km not far but no signs of anything bad. Temps have been rising. -25 today
Instagram: 709m240i
02-23-2019, 01:56 PM | #8 |
Rep 1,117
nice, definitely check the gauge dashboard for oil pressure readings, jb4 should have one as most flash do. I monitor it along with critical temps.
02-24-2019, 02:35 PM | #10 |
Rep 5,394
If temps are that low, you really shouldn't drive the car hard as the oil will take forever to get up to an optimal temp for hard driving (180 F at a minimum). I'm not sure the oil could ever get up to temp in temps that cold.
02-24-2019, 05:12 PM | #11 |
Car Geek
3727
Rep 3,632
At -30°C the M240i takes about 2km longer than usual to get to 100°C oil temperature - about 10km vs 8km at temperatures around 0°C. It has as good heat management for warmup of any vehicle I have ever owned.
02-25-2019, 02:45 PM | #12 |
Rep 109
Even with oil pan heaters plugged in all night, I wouldn't start and drive my car any colder than -20F. If it sits in a garage all day/night I've driven mine all the way down to -50F no problem. I'm sure if you don't have heaters on the pan, it just doesn't like starting and running with the thick cold oil. Are you running 0W-30?
02-25-2019, 04:02 PM | #13 | |
Rep 121
No heater. It was about -25 but a windchill close to -40. I cleared it and it hasn't came back yet.
Instagram: 709m240i
02-25-2019, 05:19 PM | #14 | |
Car Geek
3727
Rep 3,632
02-25-2019, 06:16 PM | #15 | |
Rep 109
Back when the only car I had was my 01 325ci, I had two oil pan heaters on it and even then, starting it around -40, it would backfire, idle low and make some strange noises for a few minutes. I just made the decision when I bought the 235 that I wouldn't start it below -20 just to hopefully reduce the wear and tear on the car since I plan to keep it awhile. |
02-25-2019, 07:34 PM | #16 | |
Car Geek
3727
Rep 3,632
Our 2000 323Ci didn’t misfire or run roughly when started in the mid -30 range, but it did weep fuel very slightly below -30°C (enough to smell but not see fuel running) for about a minute after starting until the ‘o’ rings on the injectors warmed up enough to reseal themselves. Our 2010 135i would sometimes throw a misfire code below -25°C that would clear itself, if I drove off right after starting, but waiting 30 seconds or so before driving off would alleviate that. I’ve only started the M240i after sitting in -30°C weather so far as it hasn’t been too cold the last two winters, but it doesn’t have any problems at that temperature. I know some Canadian cars have had larger capacity batteries than US cars in the past, our 135i came with a 90Ah battery compared with 70Ah on the US cars, although perhaps Alaska also got the bigger one? |
4seriesNL87.50 |
02-26-2019, 12:50 PM | #17 | |
Rep 109
So do businesses and employers not have places you can plug in there in Canada? Around here, most places have headbolt outlets that people can plug their cars into and most everyone has block, oil and trans pan heaters on their vehicles. |
02-26-2019, 04:59 PM | #18 |
Rep 121
CEL came on again today(scared me)
But the only code was for my catless downpipe. I guess that is a good sign.
Instagram: 709m240i
02-26-2019, 05:01 PM | #19 | |
Rep 3,507
I was just a little kid, but I still remember my mom calling my dad at work in Bismarck to tell him that the carport thermometer was reading -40° F/C. She wanted him to go outside and make sure his car would still start. Under conditions as brutal as those, it's a wonder we survived! I lived in North Dakota, Wyoming, and Montana as a kid and can well imagine the benefits of having already-warmish fluids when returning to a car after it's been parked outside for a while. The wind never stopped blowing in those states, and it was especially strong and constant in Wyoming, where cowboys lined up at the bars at their 6 AM opening before heading out onto the range. But I digress...
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
02-26-2019, 07:06 PM | #20 |
Car Geek
3727
Rep 3,632
They do, but I’ve never bothered fitting a plug-in heater with not having starting issues with any of my vehicles when using a good synthetic oil with a low pour point. I also tend to park away from other cars in the corner of parking lots where they are less likely to have plug-in sockets.
02-27-2019, 05:30 AM | #21 |
Rep 1,220
Drives: 2015 M235ix
Catless downpipes are illegal everywhere, except for track use.
If you are seeing a code, then BMW is doing its job, thank god. Save the planet! |
