02-27-2019, 11:31 PM | #1 |
Rep 1,241
Procedure for bleeding M sport brakes
Hello all,
I'm looking to bleed my M Sport brakes for the first time in preparation for a HPDE event in late March. When researching how to do this, I came across the official BMW instructions, which mention using an "ISID" computer program to manually run the ABS/DSC pump as part of the process to fully purge the system of all old fluid and air bubbles. I guess if you do not include this step to purge the DSC pump, the brake pedal is likely to feel a bit mushy instead of firm, even after filling with fresh fluid. Are there any readily available alternatives to this "ISID" application for the DIY'er to perform a proper brake fluid change at home, either through an iPhone app + bluetooth/WiFi dongle or hardwire connection to a PC/Mac? I'd really appreciate hearing about any first-hand experiences you might have with bleeding these blue caliper M Sport brakes. Thanks!
CP911
02-28-2019, 09:14 AM | #2 | |
Rep 445
02-28-2019, 10:47 AM | #3 |
Car Geek
3727
Rep 3,632
You can use ISTA/D software on a laptop with an ENET cable to activate the DSC pump in bleed mode to follow the full procedure: https://www.newtis.info/tisv2/a/en/f...ation/GfgD7vNY
Also, the spec calls for low viscosity DOT 4 fluid, as opposed to conventional DOT 4. If conventional DOT 4 is used in low temperatures, the fluid may be too thick for correct operation of DSC and ABS. |
Maynard3861.50 |
02-28-2019, 11:37 AM | #5 | |
Rep 115
What order did you bleed the brakes?
2014 M235i
02-28-2019, 01:38 PM | #7 |
Rep 1,227
How much would a dealer/indy charge to bleed brakes and replace the brake fluid? I need to get this done before doing another HPDE but unfortunately I don't have a garage or place to do it myself.
02-28-2019, 03:46 PM | #8 | |
Rep 3,549
As a fellow Bay-Area member, if you can help me find someone to buy one of my extra spring sets, I'll swap your brake fluid for free (you provide the fluid, I like/have been using Castrol SRF for HPDEs). Last edited by FaRKle!; 02-28-2019 at 03:53 PM.. |
02-28-2019, 06:10 PM | #9 |
Rep 1,241
Thanks for all the responses!
I'm going to be using Motul RBF660 on track and then will bleed and fill up with LV DOT 4 for street use. From what I've been reading, the Motul or any non-LV DOT 4 will thin out nicely at higher track temps. I bought a Motiv power bleeder for the job. It's great that some of you had no issues without this additional step, but there are several posts out there with reports of a mushy pedal due to skipping this step. I personally will not be taking any chances on the track. The stock DOT 4 fluid in my old WRX boiled on track and the pedal was going down to the floor as a result. Not fun when coming off a 130mph straight. Sounds like I need to get my hands on this ISTA/D software. Is it universal code sold under different brands or is there just one source for this software? Is this the only non-OEM software available to perform this job? Thanks again!
CP911
02-28-2019, 08:47 PM | #10 | |
Thaumaturge
181
Rep 211
///Rich |
02-28-2019, 10:52 PM | #11 | |
Car Geek
3727
Rep 3,632
Turner Motorsports says: “Low viscosity (LV) is a thinner fluid that works better than a normal fluid in the small channels and passageways in the ABS/DSC pump. Using the heavier fluid will result in a delayed response to ABS and DSC activation and a spongy feel in the brake pedal (only during ABS stops)”: https://www.turnermotorsport.com/c-176-bmw-brake-fluid, this is consistent with other info sources. |
03-01-2019, 12:07 AM | #12 | |
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
https://www.lelandwest.com/brake-flu...ow=1&SF=4&ST=2
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
03-01-2019, 08:40 AM | #13 | |
Rep 1,241
CP911
RotorOver295.50 |
03-01-2019, 08:48 AM | #14 | ||
Newer 2er
296
Rep 474
03-01-2019, 09:29 AM | #15 |
Rep 1,241
I'm not really sure as I don't have 1st have experience trying it one way or the other, but there are plenty of people out there claiming they had a mushy pedal afterwards. I think it just depends on whether any air bubbles get pushed into the ABS pump after bleeding the brake lines through the caliper vent screws. You might get lucky and not have issues, but then again, maybe not so lucky...
CP911
RotorOver295.50 |
03-01-2019, 03:13 PM | #16 |
Rep 2,882
Great info on the details of the ISID, and more confirmation that push-style bleeders are preferred to vacuum style (at least that is what the factory is using). I think this coding is necessary to fully change out brake fluid, but like an oil change, it isn't fatal to have a little residue of the old left behind. Those 'plenty of people' who note mushiness have to be greatly outnumbered by those who adequately bleed old-style before and after track days (I know 'mushy pedal' is not a common result of those I've talked with, and lots of other possible errors that could cause this). FWIW, I've heard many times that if you don't knock on the calipers to loosen bubbles, you are prone to get that mushiness; also common if the fluid has been boiled on track and you don't replace enough of the old.
For those of you still under the maintenance plan, they will replace brake fluid - either at the 2 year point, or perhaps 'as needed' (like if, somehow, some water got into the reservoir, so that one of those brake test pens showed it was needing replacement?). Probably best to also be free of obvious signs of tracking, like swap out those aftermarket pads and take the numbers off ). |
03-01-2019, 04:20 PM | #17 |
Rep 5,394
I just had the 30K warranty service done on my 2016 M235 and brake fluid replacement was one of the items they covered. I inquired about how easy it would be for me to do it once out of warranty and they said the issue was cycling the pump as it greatly reduces chances of air getting in the lines. They said they often have people bring their cars in to remove air in the lines after they attempted the bleed. So I guess I'll be adding this to the list of maintenance items I'll have to get BMW to do. They said they charge $250 for the service.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
03-01-2019, 07:02 PM | #18 |
Rep 1,241
Yeah, $250 seems to be the going rate for the dealer service. Not horrible if doing it every couple of years of street driving, but for someone doing even 2-3 track events a year, that adds up way too fast when factoring in the fluid changes back to low-viscosity DOT 4 for normal daily driving after the event is over. I feel like I really don't have a choice but to invest in the ISTA+ software (Developed by Rheingold and formerly known as ISTA/D), which seems to run for anywhere between $16 for a download to $130 for a hard-disk drive pre-loaded with the software. Then, an ICOM cable is needed and these seem to go for anywhere between $200 for aftermarket to ~$800 for the official BMW part number. Need a Windows PC as well, so I need to sacrifice half the RAM on my MacBook to run VirtualBox (virtual Windows machine), or more likely, I'll just buy a cheap Lenovo PC for garage use.
Still researching exactly what the best route is in terms of reliable software resellers and hardware, but so far this all seems pretty straightforward.
CP911
03-01-2019, 07:39 PM | #19 | |
Car Geek
3727
Rep 3,632
In terms of software download, it is worth looking here: https://www.car-auto-repair.com/bmw-...win7win8win10/ |
03-01-2019, 07:54 PM | #20 |
Rep 1,241
Isn't the ENET cable different from the ICOM cable? ENET is ethernet >> OBDII. I believe this is used for coding/programming and possibly diagnostics/servicing of older BMWs, however, my understanding is that an ICOM cable/device is required for using ISTA+ to perform manual operations like running the ABS pump during the brake bleed service on newer F-series cars. Someone correct me if I'm wrong, please.
CP911
03-01-2019, 08:05 PM | #21 |
Rep 3,549
You can use an ethernet-->OBDII cable for ISTA. I do it all the time.
The SW is free, there are various forum links to the download locations along with guides. I admit, the install process can seem challenging. I've never felt the need to run the ABS pump while bleeding/changing my brake fluid, and I track my car about 10 days a year. I use a pressure bleeder (started with the Motive, but have since switched to the Schwaben as I really like the QD feature). |
03-01-2019, 08:24 PM | #22 | |
Rep 1,241
Curious, what is the quick disconnect feature for on the Schwaben bleeder? I looked at it briefly, but never noticed a QD feature, and the reviews for the Motiv bleeder were nothing but positive while the Schwaben unit had mixed reviews.
CP911
