03-10-2019, 12:06 PM | #1 |
Rep 212
BC Coilover Issue
What's up guys I been on this forum for years I don't post much at all I usually find everything by searching. I'm new to coilovers but I just received my BC Coilover Extreme Lows and when I ordered them I know I ordered 3 bolt version. Well they sent me 5 bolt version by mistake maybe because a few days after my order I called them to upgrade to swift springs so they messed up my order and it's Sunday they're closed so I can't call them. Anyway I was wondering since only the fronts use the 3 bolts can I just swap out the top camber plates and ask them to send me the correct 3 bolt version. This way I don't have to send the whole set back cuz the set is heavy af. Also it's a rookie question but will this affect my coilover in any way by removing and replacing that top camber plate with a different 3 bolt one. Like will it mess with my settings or with the way they set them up from the factory? Also is it simple to remove and install the new one? I'm pretty sure that's the only thing different from a 3 bolt and 5 bolt coilover right? Thanx for any advice I'm really pissed cuz i waited like 3 months for these since they are custom "extreme lows" with Swift Springs and now this.
03-10-2019, 12:59 PM | #2 |
Rep 10,322
There isn't a perfect answer - unfortunately. I'd concentrate on trying to obtain the product that was ordered the first time for the right reason.
03-10-2019, 01:01 PM | #3 | |
Rep 212
03-12-2019, 11:49 PM | #4 | ||
Rep 1,934
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
