F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Diagnosis Help - P0171 Lean Code
GetBMWParts
      03-20-2019, 02:00 PM   #1
oski
oski's Avatar
15
Drives: 2022 430i Gran Coupe
Hey fellas,
I'm trying to diagnose a lean DTC code P0171 on my 14' 435i. I did once receive a code for o2 sensor circuit slow switching from rich to lean for the downstream sensor. I have done a boost leak test and tightened down clamps on my chargepipe and other seals past the turbo outlet. The car does shudder at time when at cruising or low throttle situation. Car runs fine when driving hard. I replaced the MAF sensor so that should not be the culprit. I also cleaned MAP sensor with CRC MAF sensor cleaner. Below are the freeze frames from my OBD II app. Short term and Long term fuel trims are confusing me since I would thing the long term would be lower since the short term is negative. Only intake mod is a K&N filter in a mppk lower airbox (no mppk tune) Thanks for any help!
      04-09-2019, 10:56 AM   #2
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Is your car stock? Any modifications?
      04-11-2019, 03:48 PM   #3
oski
oski's Avatar
15
Issue was resolved once I remove the MPPK lower intake box... I guess the stock tune doesn't like the extra airflow. Time for Bootmod3.
f30post
