E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > DSC Malfunction need help please
Reply
      03-21-2019, 10:34 PM   #1
aLbe
Drives: s2k & 335is
Hi, i recently replaced Serpentine Belt, Tensioner, pulley, oil cooler gasket and coolant flush. while i was bleeding the coolant it was shooting out from the bleeder gap for 10 minutes straight non stop i had to put a rag on top of the cap and it was draining down onto my vacuum line/ 2 vacuum box i don't know what this box is called it has 3 vacuum line going into each box its located on the right side of the coolant reservoir near the bottom of the injector , coolant was getting all over my engine( valve cover off) i had to stop the bleeding process because my 7 liter oil pan catcher was getting full. after i empty my oil pan catcher i redid the bleeding but this time the pump turn on and off not contanly on like before. After the bleeding i hose my engine off with water.i start the car at idle for about two minutes, then I started revving it and the first few light revs were fine. It came back to idle just fine with no indication of any problems. Then, I opened up the throttle and heard a pop. The car went into reduced power with DSC faults and threw codes. The revs just bounced from 1000-1500 rpms.
P1638 Throttle Valve Position Control; Throttle Stuck Temporarily
P1633 Throttle Valve Adaptation; Limp Home Position
P1639 Throttle Valve Position Control; Throttle Stuck Permanently
Also i heard a small hiss/whine coming from the vacuum box after i turn off the car but it went away few mins later, the passenger side sensor from the wheel well(in a black box) got soak from the coolant/water.
Thank you
      03-22-2019, 02:25 PM   #2
MysticRob
MysticRob's Avatar
573
Drives: 2009 335i E90
Not sure what kind of coolant flush process you used, but I don't recall anything about coolant shooting out everywhere in the how-to videos I watched.
Let the car dry, remove the battery leads to kill power to all modules for a couple hours, check fuses in the meantime, then put it all back together and let us know how it goes.
Unfortunately it could be worse than simply drying things out.
2008 E61 535xi Sport Wagon / 100k Miles / Deep Sea Blue Metallic / Natural Brown Interior / MHD Stage 1 91 CA-Octane Tune.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2.
      03-27-2019, 05:26 PM   #3
aLbe
Drives: s2k & 335is
Fix the problem, my charger pipe gasket got stuck between the throttle body gate
Reply
e90post
