03-23-2019, 07:43 PM | #1 |
Rep 770
Display key questions for those who have it
1) how many of these do you get?
2) if you choose the display key option, do you still get 2 of the smaller regular key fobs for days when you don’t want to carry the big azz display key in your pocket? 3) are you happy with the extra functionality, or has the novelty worn off and you’ve gone back to using the smaller fobs? 4) can you get a display key made by the dealer after the fact, even if you originally didn’t order the option on your car?
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7 |
03-23-2019, 07:55 PM | #2 | |
Rep 2,717
03-23-2019, 08:00 PM | #3 |
Rep 313
2019 X7 with display key here.
You get one display key, one regular key, as noted above. I've only had it for a few weeks. It's pretty nice. The main feature I use so far is to start the engine and climate control the car before I leave the place I'm leaving (store, home, etc.). You can remote start and do that stuff from the app, but it's a lot easier from the display key. Don't know if the novelty will wear off, but so far it's pretty cool, and I'm happy to have it.
2019 X7 50i carbon black, M package, premium, executive, fully loaded, fast as all get out
Wild Blue3683.50 |
03-24-2019, 07:53 AM | #4 |
Rep 25
We live in a pretty cold climate, so having a remote starter is critical. Is the display key the only way to get the car to start remotely or can the iphone app do the same thing?
The iphone BMW app has terrible reviews by the way, so I'm not sure it is an alternative. I'd like to avoid having my wife constantly carry this big bulky display key. |
03-24-2019, 08:08 AM | #5 | |
Rep 313
03-24-2019, 08:25 AM | #6 |
Rep 25
If the regular key allows remote start, what would be the benefit of having a display key? Just to get vehicle info (mileage) etc?
03-24-2019, 11:37 AM | #8 |
Rep 2,717
I was just looking at the owners manual.One more thing you can do with the display key and not the regular key is adjust the ride height of the air suspension when you are outside of the vehicle.
03-24-2019, 11:53 AM | #9 |
Rep 2,717
One other feature the display key does and not the regular key is remote park the vehicle with the key.This is a very convenient feature if you need to park the vehicle in a very tight parking space.
03-24-2019, 12:15 PM | #10 |
Rep 9
03-24-2019, 12:43 PM | #11 |
Rep 1,115
03-24-2019, 01:46 PM | #12 |
Rep 1,489
Drives: 2023 iX xDrive50
That's very disappointing if it's not available on the X7 in the US. I have remote park on my G30 and I find I use it much more than I thought I would. Mainly to pull out of a parking space when someone jams me in and I don't feel like contorting to open the door and slide into the driver seat.
03-24-2019, 02:14 PM | #13 | |
Rep 65
03-24-2019, 03:21 PM | #14 |
Rep 2,717
Thanks for the info.I just assumed that since my wife’s 540i has remote parking with the display key,the X7 would also have the feature.I just looked in the owners manual and there is no listing for remote parking.Hopefully a future software update will enable remote parking.
03-24-2019, 03:50 PM | #15 |
Rep 61
Display key just seems like a novelty. Who really uses it? I have a display key that came with my 750 and haven’t seen it in months. Thing is huge. Who is remote parking into a tight spot? Let me just ding your door for you before hand because the car next to you most likely isn’t remote parking in or out. Im assuming the X7 has a suspension setting for easy access and lowers when you park similar to range rover/XC90/ every other car with air suspension
SaintD4.00 |
03-24-2019, 04:41 PM | #16 |
Rep 1,115
I would just order if for fun. On the one hand, it's not a feature with a high value (gadget) but on the other hand, do $300 really matter on such a vehicle?
03-24-2019, 04:53 PM | #17 | |
Rep 2,717
PIPE_DR Is there a setting in IDrive that automatically lowers the air suspension to the lowest setting every time you park the car?Does the X7 also stay in the lowest suspension setting when you get out of the vehicle and lock the car? |
03-24-2019, 06:27 PM | #18 | |
Rep 1,489
Here in the Seattle area the spaces are quite narrow and it's not uncommon to return to your car only to find some inconsiderate driver jammed me into a tight squeeze. Pulling out with the remote is much easier than trying to squeeze my way in. The only real downer to remote parking is that the car needs to be turned off before entering the vehicle after pulling out of the space. Parking INTO a tight spot is the atypical scenario. I would never use it for parking INTO a space unless I'm in a parking garage and find that rare narrow space between two concrete structures that no one wants to park into. |
03-24-2019, 09:15 PM | #19 |
Rep 321
Nantucket, My X7 does not have an auto lowering setting for parking. As a matter of fact there are no air suspension settings in idrive that I've seen. That may be different with off road package, but not sure. the only control I have is rocker switch, driving modes and trunk button. Ill try lowest setting and locking to see what happens tomorrow.
SW192465.00 |
03-25-2019, 04:22 PM | #20 | |
Rep 3,479
03-25-2019, 09:10 PM | #21 |
Rep 321
So I tried a couple things. When I set the car at the lowest level this evening (via rocker switch) got out and locked the door. It staying at that setting. I then put the car in sport mode, took it for a drive, got out and locked the door. It returned to standard ride height.
03-25-2019, 09:45 PM | #22 | |
Rep 2,717
