03-27-2019, 07:55 AM | #1 |
Rep 343
Drives: '19 750i xDrive
No Comfort Plus Mode
Test driving the X7 I was unable to find a Comfort Plus mode, which is offered in the 7 series. For those of you that have taken delivery of your X7s, can you verify the X7 does not have Comfort Plus mode?
Thanks |
03-27-2019, 09:32 AM | #2 |
Rep 770
If I'm not mistaken the comfort plus mode on the 7-series sedan is based on the following as detailed on an article I found on autoblog:
"a complex system called Active Comfort Drive with Road Preview adds anticipatory functions to the active chassis with air suspension, while the Integral Active Steering (variable-ratio rear-wheel steering) now comes with all-wheel drive. The automatic transmission downshifts on its own, based on what the navigation system tells the transmission about the road ahead, for example a hill" What seems like the equivalent of this system is optional on the X7 via the $4750 Dynamic Handling package. Details on the X7 configurator describe this system as: Active Comfort Drive with Road Preview Active Comfort Drive's electromechanically-operated stabilization system allows your vehicle to handle corners with comfort and precision. Road Preview uses a forward-facing camera mounted behind the rear view mirror to read the road surface and adjust the suspension system in real time via the Dynamic Damper Control system. Together, they impart an unrivaled combination of sporty handling and luxurious riding comfort. Integral Active Steering Integral Active Steering maximizes agility at low speeds and maximizes stability at high speeds. At lower speeds, the rear wheels turn oppositely to the front wheels, allowing for a sharper turning radius thereby making parking and cornering easier. At higher speeds, the rear wheels turn in the same direction as the front wheels, which helps improve vehicle stability and lane change comfort. Probably not as sophisticated as the comfort plus mode of the 7-series but I'm sure it's not far off if not nearly equivalent in effectiveness. To me the ride quality in X7 is equally as superb as the 7-series. If anything, the 7-series just benefits slightly more from plusher rear seats.
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7 |
03-27-2019, 11:06 AM | #3 |
Rep 2,599
The X7 is not a true 7 series that’s lifted more of a stretch X5, hence the missing mode and hence the price difference between the 7 series and X7. It’s still comfy with air suspension .
03-27-2019, 11:11 AM | #4 | |
Rep 76
03-27-2019, 04:41 PM | #8 |
Rep 76
I press Comfort twice to get Comfort Plus. My wife's 5 only has Comfort.
03-28-2019, 07:24 PM | #9 | |
Rep 1,489
Drives: 2023 iX xDrive50
Comfort plus made my F10 feel like a Buick. It's a matter of preference but it certainly wasn't for me. My G30 doesn't have Comfort Plus and I certainly don't miss it. |
08-03-2019, 02:58 PM | #10 |
Rep 442
Drives: 2023 BMW iX M60
Now we know, G07 has comfort plus, it is just hidden. I did spent two hours comparing comfort and comfort plus, no real difference. Sport Plus, however, is a different story.
yans29.00 |
05-20-2020, 10:06 AM | #11 |
Rep 99
05-20-2020, 01:27 PM | #12 | |
///M SubDriver
1840
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
As far as what it offers, based on my experience with an X5 40i loaner that had it, you get more aggressive throttle mapping for the engine, more aggressive/quicker transmission shifts (up & down), stiffer steering, and stiffer suspension. I have not coded my X7 for this functionality, but I suspect it will be very similar if not exactly the same.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
cvp3332.00 |
