03-31-2019, 03:13 PM | #1 |
Rep 77
kW coilovers options at same ride height
Have a 340i xdrive which has about 2.5 inch gap on the front and I'd like to cut that in half. I've read that the comfort levels change the lower the car is dropped for a given coil over set. My question is how would street comforts at the lower end of their adjustment range compare to say v1 or v2 at the same ride height which is closer to the higher end of their adjustment range?
03-31-2019, 04:16 PM | #2 | |
David
787
Rep 2,009
Street comfort also has adjustable rebound dampening which unlike fixed setting struts it will give you a greater range to get your desired ride quality. Hope i answered your question |
03-31-2019, 05:03 PM | #3 |
Rep 77
Sort of. Guess what I'm saying is in terms of comfort am I better off getting street comforts and adjusting to the lower end of the ride height adjustment or getting v2 and keeping on the higher end of the adjustment range. Maximum Ride height is lower on the v2 so lowering of say 1.5 inches is closer to the top end of the range on v2 and bottom end of the range on street comfort.
03-31-2019, 08:48 PM | #4 | |
David
787
Rep 2,009
Get comfort for comfort, and v2 for performance |
03-31-2019, 08:59 PM | #5 |
Rep 77
Makes sense. I was just thinking street comforts on the lower end would have less compression travel left than say v1 or v2 at their highest setting. The car would ride the same height but have more compression travel on the v series. And v2 has rebound adjustment like the sc. Maybe I'm looking too much into it. I'm pretty set on the sc already just hoping comfort levels are ok with a 1.5inch drop.
03-31-2019, 10:23 PM | #6 |
Rep 122
I think the first reply nailed it, if you adjust height with the shock body and not the preload adjustment, you shouldn’t notice a difference in ride. Also, you’d have to get a rear coil booster for the v1-v2 to only lower it by half in the rear. Their max height is pretty low.
Operator Mo64.50 |
03-31-2019, 10:38 PM | #7 | |
David
787
Rep 2,009
04-06-2019, 04:03 PM | #8 |
Rep 1,934
Street comfort are fine on the track as well. They get the comfort name because at their highest they are only 10mm lower than xdrive height. The springs and valving match this. The V series are 30mm from xdrive at their highest. You can take either to the track. Someone here posted that the SC did just fine.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
04-06-2019, 07:37 PM | #9 |
Rep 10,317
KW Street Comfort coilovers will be just fine on the track. More important concerns on the track: brake pads and tires.
Operator Mo64.50 casualDIYer447.50 |
