04-03-2019, 12:51 PM | #1 |
Chuggin' Along
333
Rep 588
Fattest, stickiest tires on stock rims
Guys,
I am looking for someone who had fitted some 275-295 width rear tires on their stock wheels. If you're lowered a bit, as I am on H&R springs, that would be helpful to know also. I'm going to have serious traction problems soon, and trying to be proactive. |
04-03-2019, 04:11 PM | #4 |
Rep 6,977
Drives: 2018 M2 AW DCT
Lots of people are running 255/35/19 in front and 275/35/19 in back with no problems.
https://f87.bimmerpost.com/forums/sh....php?t=1468422 |
04-03-2019, 04:40 PM | #5 | |
Chuggin' Along
333
Rep 588
04-03-2019, 04:46 PM | #6 |
Rep 1,204
There's some older threads from Apex where they mounted some 305/35/18's with their wheels...so big meat can fit.
I think R888R 265/35/19 fronts and 285/35/19 rears could be done. Probably need a small spacer in the front with a nice camber of -2 to -3 range I would hope. I like the extra sidewall of the 35 profile. Otherwise the 265/30/19f and 295/30/19r or 305/30/19r.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder Last edited by Commanderwiggin; 04-03-2019 at 04:53 PM.. |
04-04-2019, 02:52 PM | #7 |
Rep 12,654
Bridgestone RE71R + 275/35/19! (Safe route)
Do you plan on playing with the camber at all? 295/30/19 R888R has been done as well..... |
04-11-2019, 08:49 PM | #10 |
Rep 521
id be careful running 265 in the front with R888R as the toyos are slightly wider than most tires of the same specs, and likely will rub on max compression. you can easily run 285 in the rear on stock, but havent tried when lowered. im on v3's and run 255/275, but i think i can go wider in the rear if need be.
04-13-2019, 12:52 PM | #11 | |
Rep 450
04-13-2019, 12:55 PM | #12 | ||
Rep 521
