04-03-2019, 11:16 PM | #1 |
Rep 756
DP, Midpipe, or rear section?
New m2C owner and owner of many a BMW with modified exhaust. Things are less clear for me on the m2c. Here are my former cars and setups I ran:
e92 335i n54: catless downpipes, stock midpipe and rear- overly raspy e92 335i n54: high flow cat downpipe, stock midpipe, 335is rear section- great e92 m3: catless downpipe, resonator, high flow secondary cat, stock rear- great I just finished break in on the m2. Will probably just run a CS map. The stock m2 comp is just a bit too muted in sound, both intake and exhaust. The burbles in sport plus are fairly loud. I plan to remove the charcoal filters and probably add BMC filters. I would like the exhaust to be 15% or so louder and I'd like to disable the ASD. For the exhaust, I am debating the following independent of eachtother: AR Resonated Downpipe- Save 7 lbs, but lose warranty, don't really need downpipes for a mild tune like the CS AA Midpipe- Saves 10-15 lbs I think? Smoother sound? A bit of power? Rear Section- I would go for something fairly conservative here, maybe a (gasp) Dinan or MPE, or sport axel back, Save 10-15 lbs. In the past I would have gone downpipes immediately but the s55 is making nearly enough power stock and therefore options 2 and 3 are a bit more appealing to maybe keep warranty. Anyone else is going the OEM+ route please chime in. - |
04-03-2019, 11:23 PM | #2 |
BimmerPost Supporting Vendor
24339
Rep 191,107
Can't go wrong with Active Midpipe and/or REMUS exhaust
04-04-2019, 05:39 AM | #3 |
Rep 563
04-04-2019, 10:23 AM | #4 |
24339
Rep 191,107
Yes its been reported that both are compatible on the M2 Comp
04-04-2019, 11:49 AM | #5 |
Rep 877
Drives: ///M2
After hearing a MPE M4 w/ catless DP's and another with comp exhaust, stock DP and no secondary's or res, I'm convinced a pair of catless DP's on the stock mid section is perfect. You get the extra sound with being too raspy/annoying with all the performance you need. The rear end would be great stock or something mild, maybe a Dinan exhaust, etc.
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek) |
04-04-2019, 02:39 PM | #7 | |
Rep 12,654
Judging by how the driver's side piping comes together it might be a very close fit where the Remus would be pushed out very slightly or one of the pipes may need cutting: We are looking for someone local to fit this combination if any OC or LA forum members are interested in this set up |
04-25-2019, 05:19 PM | #8 |
689
Rep 6,854
Lovely car, Check out the Eisenmann Valved for the Comp., It sounds great!
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
04-26-2019, 05:50 PM | #9 |
Rep 456
This is what I've just had done yesterday. I also installed the ASD bypass and I'm eager to get out in the dry to really hear what this setup sounds like up close 😎
2019 HS DCT M2 Competition with Essex AP Racing Radical Pro5000r front and rear BBKs, Bilstein B16s and 763M wheels with Cup 2s
COChris888.50 |
