Defective wiring in headlight buckets
04-06-2019, 12:59 PM | #1 |
Rep 67
Angel eyes bulb went out and found this when I went to replace it. What's left of the insulation is brittle and flaking off. It appears to only be the wires coming out of the plug.
04-06-2019, 02:45 PM | #2 |
Rep 231
I had the same issues on my 07 E92, I taped it all up with electrical tape and it's been fine since.
04-07-2019, 09:37 PM | #3 |
MisterR247365.com
409
Rep 380
Drives: 335i M-Sport Cabrio (E93)
Had the same issue on both sides...wrapped it in electrical tape as well.
04-08-2019, 08:05 AM | #4 |
Rep 11,905
happens because of the heat build up from the bulbs
Only the wiring loom above the bulbs seems to be affected The rest of the wiring is usually not brittle at all Danger here is the bare wires can cause a short and blow your expensive xenon headlight bulb or ballast The headlights can be opened up and disassembled pretty easily (see link below) so you can replace the brittle wires or you can poke around through the top hatch and try to wrap them in electrical tape or heat shrink Good luck https://www.e90post.com/forums/showthread.php?t=1593166 |
04-08-2019, 09:32 PM | #5 |
Rep 342
The problem is the when people replace the bulbs they don’t seat the bulb correctly and it backs out. When that happens the bulb heats the wiring to the point insulation becomes brittle. The ‘design flaw’ is that it’s difficult to seat the bulb correctly in the housing. The real problem is people incorrectly replacing bulbs.
