04-09-2019, 12:51 AM | #1 |
Rep 77
EDC to passive CO's front strut configuration
So I almost pulled the trigger on the KW Street comfort coilovers but I stumbled upon a few posts regarding the front strut end link mount is different between EDC and non EDC cars. Non EDC cars have the same strut on both sides just flipped 180 degrees and EDC cars have two different struts that are mirror image of each other. Do the KW co's take this into account when ordering or are new end links required?
As far as I can tell the KW sc part numbers 1802000S is regular and the 1802000U is the same but includes the EDC delete kit. |
04-09-2019, 07:28 PM | #2 | |
Rep 1,523
04-09-2019, 07:33 PM | #3 | ||
Rep 625
I had EDC on my f30 and it's slightly different OP... the only thing you'll need to change is the end links ... strut will fit fine |
04-09-2019, 09:42 PM | #4 | |
Rep 1,523
his car is xdrive, hes not going to need to change anything if buying non edc xdrive kit. |
04-09-2019, 09:44 PM | #5 |
Rep 77
I was under the impression that cars with EDC have different left and right struts. Looking at realoem the part members for the right side strut and end link are different. The problem I read was that manufacturers don't account for this and just make the front struts the same for both L and R sides so when used on a car with EDC is when the problem comes up.
04-09-2019, 09:53 PM | #6 | |
Rep 1,523
- ALL xdrive cars regardless of edc equipped or not have different L and R struts in the front. left endlink 31306792211 and right endlink 31306792212 http://www.realoem.com/bmw/enUS/show...diagId=31_0951 - Only rwd cars without edc have the same struts on both sides. Same endlink on both sides 31306792212 http://www.realoem.com/bmw/enUS/show...diagId=31_0951 Last edited by M4_GTS; 04-09-2019 at 09:58 PM.. |
04-09-2019, 10:55 PM | #7 | |
Rep 77
But this in on the internet too! But seriously if that's the case then ok thanks. Guess my question in the end is I have xdrive and EDC so different struts and links on each side. Does the kW SC for xdrive with EDC delete kit 1802000U account for this straight bolt on no endlinks needed? |
04-10-2019, 08:33 AM | #8 |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
this is definitely interesting information. I am RWD and have EDC and I am just finding out now that the front struts are different. I am planning to get coilovers in the future so I too wonder if companies have accounted for this.
What exactly is the difference from left and right front struts? |
04-10-2019, 10:46 AM | #9 |
Rep 77
My other concern is I'm hoping the shocks will have the mounting brackets for the accelerometers. Apparently these still need to function with the EDC delete kit or VSS could be effected. Again this is just what I've read on these forums I have no confirmation it is accurate I'm hoping someone on here can confirm. I've found photos of the shocks and seems like they do have the mounts so fingers crossed everything goes smooth.
I was going to install them myself but I found a kW dealer install shop in Vancouver that includes install and alignment for a reasonable price so it will be in there hands. |
