04-09-2019, 09:14 AM | #1 |
Rep 1,208
BMW Cross Bars + Thule Motion XT XXL
These are the x7 crossbars i bought from Getmybmwparts.com
plus a Thule motion XT XXL. have yet to clamp the box on to the bars but fit looks good. won't go over the windshield, wont interfere with tailgate or antennae |
04-09-2019, 09:29 AM | #2 | |
Rep 475
2014 A207 E550 Vert
2018 F60 Countryman S All4 2019 G07 X7 40i |
04-09-2019, 09:35 AM | #3 |
Rep 1,208
i dont know a ton about cargo boxes but i think i'll need to slide it forward a couple inches so that the cargo bars line up closer to the center of the underside carve out. (see blue arrows)
04-09-2019, 10:16 AM | #4 |
Rep 770
Perfect!
Funny how an XXL sized Thule box can look small-ish on the X7
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7 |
04-09-2019, 11:14 AM | #5 | |
Rep 475
2014 A207 E550 Vert
04-09-2019, 11:17 AM | #6 | |
Rep 1,208
04-09-2019, 01:12 PM | #8 |
Rep 1,654
Nice setup! Can you confirm that the bars are two different lengths? I’m nervous about the set I purchased prior to taking delivery of the car. About 1.5”, yes? Thanks! |
04-09-2019, 02:06 PM | #9 |
Rep 1,208
Mine have a difference in length too but not sure if 1.5”. I think you and I bought from same place so you should be fine. Critical thing is you find the notches under the roof rail that show where they go
04-09-2019, 03:02 PM | #10 |
Rep 475
Ah that's right. I recall seeing pictures that the bars are different lengths - which would imply that there's only 1 place to place them. Good to know. I might want to wait until Yakima or Thule officially endorses a kit. Yakima already kind of does.
2014 A207 E550 Vert
04-09-2019, 09:59 PM | #11 | |
Rep 1,654
For my X5 using the BMW bars that are identical in construction and function as these X7 bars, one can actually place the two bars any reasonable distance apart to fit any number of cargo boxes. The X5's bars came with handy decals that you could put in the door jambs to remind yourself where to place them the next time. Are you saying there are specific notches that space the front/rear bars apart (that would be something new) or are you saying that there is a long notch that runs the length of the left/right roof rails that the cross bars snap and lock into (same function as X5)? |
04-09-2019, 10:59 PM | #12 | |
Rep 430
04-10-2019, 04:49 AM | #13 | |
Rep 1,208
Yes, check out the instructions. You’ll see mention of this there too. About 29.5” apart. And make sure you open up each foot to see where it goes. You need to identify the front bar from the rear bar AND the driver’s side from the passenger side. Label inside foot will say something like FL (front left) for example Last edited by ppagiga; 04-10-2019 at 05:54 AM.. |
04-10-2019, 09:17 AM | #14 | |
Rep 1,654
Interesting. This may complicate my install of my existing X5's Thule. Fingers crossed. |
12-13-2019, 03:05 PM | #16 |
Rep 1,208
12-13-2019, 05:26 PM | #17 |
Rep 281
Is there any noticeable wind noise or drag felt at cruising speeds? I like the setup but I'll have to dismount it immediately after each trip bcos of office parking lots and garage.
I've been thinking about rooftop and hitch mounted rack. |
12-13-2019, 09:07 PM | #18 | |
Rep 1,654
Same for drag, that's not an issue with a car of this size. |
12-13-2019, 09:52 PM | #19 | |
Rep 1,654
The bigger question is what size do you need. Keep in mind that these things are rather large and cumbersome to store and put up on the roof, so an L or XL might be best. |
Brukes90.00 |
12-14-2019, 08:23 AM | #20 | |
Rep 130
Should be compatible with Thule boxes (though I have the Yakima Showcase 20). |
12-26-2019, 08:59 PM | #21 | |
Rep 2,011
Drives: 2022 i4 M50
Without the cargo box it is less frequent, but I'll get a high pitched whistling on occasion at speeds upwards of 55 MPH and a slight cross cross wind. With the box on, especially when empty, the more typical wind noise is very apparent above 60MPH. Its certainly not as bad as other cars or boxes but its definitely there. Below 45 or so and there's nothing, so that's good, the high pitched whistling also goes away with the box on, I think it's something with the rubber inserts in the middle of the bar not having pressure on them, maybe that will fix itself over time, but I dont think I'll ride around with just the bars on anyway, they certainly come off easy enough. Last edited by unfoundnemo; 10-24-2020 at 06:54 AM.. |
12-28-2019, 06:56 AM | #22 | |
Rep 1,208
Other thing to keep in mind is to try to keep it at 80mph or less, other than that, biggest adjustment for me is the height. Few parking garages can accommodate this set up, unfortunately, and need to be constantly mindful of clearance when you have a big box on top like this one in XXL capacity |
