04-09-2019, 12:41 PM | #1 |
Rep 69
Radar Detector Hardwire
Has anyone attempted to hardwire a radar detector and/or dash cam in the G20 yet? I've been looking around trying to figure out the best location and haven't had any luck finding a switched 12V source. Here are some key points so far:
1. Fuse box in the trunk: 1.a. This location would work; however, there doesn't seem to be a good place to ground back there. Everything you can see/feel when removing the little cover piece exposing the fuse panel is plastic. Admittedly, I haven't removed any carpet to expose metal. 2. The fuse box in the passenger foot well: 2.a. This fuse panel seems to be ideal, several places to ground and shorter distance to run wire; however, I cannot find a switched 12V. Each fuse location I try is constant power. I haven't tested any of the mini fuses bc the AAC I have is standard, so I was hoping to find a standard fuse to use. If I need to purchase a mini AAC, I'm sure the $10 won't "break the bank" LOL. 3. Mirror tap set-up: 3.a This is by far the easiest answer. I've done it in all my vehicles and have the mirror tap wires already that I removed from my trade in; however, I have no idea which pins do what. There are two connectors under the mirror trim piece. A larger black one feeds wires into the mirror itself and the smaller red one. I'm assuming the red one is for rain sensing wipers (?) I've called my local service dept, and they either were unwilling to tell me or just didn't know, but I got nothing out of them. I called a buddy of mine who works as a mechanic at an import shop, but he said they haven't received wire schematics or much information on the G20 yet. |
04-09-2019, 03:22 PM | #2 |
Rep 500
I did this with my F30
But to be honest with just about every vehicle being a radar transmitter these days, detectors are becoming useless. Instead of even turning mine on anymore I just use Waze. |
claykin1591.50 Eagle Creek139.00 |
04-09-2019, 04:07 PM | #3 |
Rep 69
My last detectors had fits with all the new cars, but the ones I have now (Escort Redline in G20 and Escort Max 360 in my truck) very rarely trigger on cars’ safety sensors.
I’ve seen those setups like you have in other cars. Might be worth looking into if I cant figure something out |
05-26-2019, 08:48 PM | #4 | |
Rep 572
Did you ever find a spot? |
05-27-2019, 08:42 AM | #5 |
Rep 583
I would like to hardwire my RD to my mirror mount however, I agree that with today's BSDs and autonomous vehicles, false alarms impossible to tune out. I have resorted to Waze which works extremely well in the G20.
2003 328i
2006 330i 2014 328i 2015 435 GC 2015 X1 2016 X1 2018 ///M2 2020 M340i |
06-16-2019, 09:21 AM | #7 |
Rep 111
Agreed. Waze is the way to go and significantly more accurate
2022 BMW ///540i xDrive Bernina Grey Metallic Amber Effect
2019 BMW X5 40i ///M-Sport (Recalled) Mineral White Metallic 2011 Porsche Panamera Turbo S (Sold) Basalt Black Metallic 2009 BMW X6 50i Dinan (Sold) Alpine White 2003 BMW ///M3 (Sold) Laguna Seca Blue | 1995 BMW ///M3 (Sold) Santorini Blue II |
07-03-2019, 07:25 PM | #8 |
Rep 128
Sunroof?
Will later be in similar position and wondering if not able to hardwire via sunroof? Have done this with previous BMWs and would think be able to do same with M340i unless BMW has changed wiring around now.
https://f80.bimmerpost.com/forums/sh...9#post16506202 |
10-11-2019, 01:11 PM | #9 |
Rep 1,037
Did anyone end up doing this?
10-11-2019, 04:50 PM | #10 |
936
Rep 4,327
Drives: M340
I ended up using the mirror tap from my F10 but have not finalized my install yet. I can take pics if anyone is interested.
One thing I figured out it that I need a new radar detector as my Passport 9500 doesn't like the G20 AT ALL even with gesture control turned off. Hard-wiring a dash-cam isn't any different than other BMWs
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
10-12-2019, 02:58 PM | #11 | |
Rep 1,037
My Max 360 laser alert was going off constantly, I turned it off because laser alert is pretty useless anyway
M340i: Arctic White, 790M wheels, Cognac interior, Aluminum Tetragon trim - Totaled
10-13-2019, 07:15 PM | #12 | |
936
Rep 4,327
Drives: M340
May be before going and buying another detector, I should try turning off the laser. But I am due for a new detector, thinking about picking up a the new Max360C.....wonder how that will behave in this car?
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired Last edited by TTG; 10-16-2019 at 11:49 PM.. |
10-16-2019, 10:04 PM | #13 | |
Rep 456
2018 BMW M5
2018 Porsche GT3 2023 Porsche Macan S 2023 Porsche 911 Turbo S |
10-16-2019, 11:51 PM | #14 |
936
Rep 4,327
Drives: M340
I did turn off Laser and it is behaving much better now. But here in WA our State Patrol do use laser.......but then, once they buzz you, its too late anyway.
10-21-2019, 06:35 PM | #15 |
Rep 146
Blind Spot Monitoring (BSM) filtering is fantastic in most modern Radar Detectors. I use the Radenso XP which is very quiet, Radenso has the best reputation for BSM filtering. Radenso & Valentine are coming out with new detectors shortly. Some vehicle makes are very problematic for BSM filtering so they punch through.
Expecting December delivery of a 2020 M340 currently in production. |
10-25-2019, 07:40 PM | #16 |
Rep 1,037
I tapped mine to the 12v and ground of the top wires with the pink connector but it looks like they are always live. Do you know which you used that are switched?
10-26-2019, 11:00 AM | #17 |
Rep 1,037
Made a DIY here:
https://g20.bimmerpost.com/forums/sh...3#post25390353
02-09-2020, 03:01 PM | #19 |
Rep 230
Do you happen to remember which 12v wire you tapped originally that was always live? I plan on using this method for powering a dashcam with always-on parking mode recording. Thx.
