04-09-2019, 09:20 PM | #1 |
Rep 21
A/c problem
I have a 2013 328i and have issues with the a/c. So far I've tested the a/c compressor and also the fuse that generates voltage to the a/c and both are good. The a/c still does not work what could be the issue?
04-11-2019, 08:49 PM | #4 |
Rep 387
Do you have a black light to shine on the A/C lines or compressor? Refrigerant typically has black light dye in it to help find leaks. If you have a leak and pressure falls below a certain PSI, most, if not all modern cars have a built in fail-safe that will prevent the compressor clutch from engaging so that the compressor won’t get damaged. The only other thing I can think of is maybe a bad relay? Have you checked for voltage at the connection to the compressor?
04-11-2019, 10:45 PM | #5 | |
Rep 21
04-12-2019, 08:51 AM | #6 |
Rep 387
04-17-2019, 08:08 AM | #7 |
Rep 387
