04-15-2019, 10:12 AM | #1 |
Rep 1,420
X7 Wiper Blades
The wiper blades on out X7 (3 weeks old) were not wiping the window very smoothly. On the upstroke they tended to skip and hop across the glass rather than make a clean swipe. So today I called the service department and they replaced the blades. I ran then them on a relatively dry windshield and they seem to work properly. I'm know for sure if the new blades resolved the issue when it rains again. Anyone else noticing a similar issue with their X7 wiper blades?
04-16-2019, 11:55 AM | #3 |
Rep 1,420
My dealer could not find a service bulletin for the X7 but I'm wondering if it's the same issue on both since they're very similar in design. BMW likely sources the wiper blades from the same suppliers. But the good news is they made it right for both of us.
04-16-2019, 12:11 PM | #4 |
Rep 668
Here's the (I'm assuming X5) bulletin they referenced in case it helps: SIB 61-01-19. They noted they replaced the blades with new ones that have "double graphite."
08-13-2019, 01:15 PM | #5 | |
Rep 14
vimeo.com/user11915756/review/353629404/d1896dc13c Last edited by nornor67; 08-14-2019 at 12:44 AM.. |
08-13-2019, 06:25 PM | #6 |
Rep 1,420
The shop replaced ours about two months ago. They are working better than the original set but do skip at times. No that it is hot in the NE it's not as much of a problem. I expect it will become an issue again as it cools down this fall.
08-31-2019, 08:48 PM | #7 | |
Rep 13
09-05-2019, 05:16 AM | #8 |
Rep 14
For those who follow this item. I just found out that BMW in the Netherlands have a callback for this problem. The complete wiper installation should be replaced. I will make an appointment with a dealership and hopefully soon will be having a good wiping installation on my X7.
09-05-2019, 09:40 AM | #9 | |
Rep 6,731
Thanks!! |
09-05-2019, 11:52 AM | #10 |
Rep 14
09-06-2019, 06:38 AM | #11 |
Rep 14
dealer is looking in to it if they have such a number and would let me know. The call back is for the models produces until end of may 2019. The models production after may 2019 are not affected. The motor of the wiper needs to be replaced.
09-07-2019, 12:50 PM | #12 |
Rep 6,731
Good to know. The date range you provided affects me. I’ll keep an eye out. It hasn’t been raining here so I haven’t had to use them
10-02-2019, 01:48 PM | #13 |
Rep 14
UPDATE. The car has been back to dealer and replaced the wiper motor and blades. The problem has NOT gone away, it is now even worse than before. Besides the hopping from the blades accros the screen, now they also mee a hell of lot noice. At the moment the car is back in the shop and the dealer is going to see what causes the problem. Any one else who had this problem, but with a fix that did work out?
10-04-2019, 11:25 PM | #14 |
Rep 6,731
I, luckily, don’t have this problem. It rained here pretty good a week ago and it was smooth and quiet. I DID get a large rock chip from a truck, but that’s a different thread 🤦
10-08-2019, 05:00 AM | #15 |
Rep 1,208
Hmmm don’t have the problem but I’m a week 12 build and it’s not showing up as a service item/recall for my vehicle
