04-28-2019, 09:55 AM | #1 |
Rep 124
Battery Tender Quick Disconnect Plug
Guys -
Does anyone know what size of a Torx wrench is needed to install one of these. The biggest I currently have is a T40 which is too small. Both the Positive and Negative mounting terminals in the engine bay appear to take something like a T50. If anyone knows the correct size please let me know. Thanks. https://www.amazon.com/dp/B000NCOKZQ...v_ov_lig_dp_it |
04-28-2019, 10:40 AM | #2 | |
Rep 5,350
I am just using the clips on the charging points under the hood. It way easier to leave the hood unlatched than the rear hatch. |
04-28-2019, 10:54 AM | #3 |
Rep 124
I want to attach the quick disconnect to the charging points under the hood, not the actual battery. I did this on my last BMW. The charging points are screwed down and can be removed to permanently attach the quick disconnect. I'm trying to understand the proper Torx Size to remove them. I looks like a T45 or T50.
04-28-2019, 11:22 AM | #4 | |
Rep 5,350
