04-30-2019, 03:29 PM | #1 |
Rep 5,413
Drives: 2015 BMW 335i x-Drive Auto
2-Piece Brake Rotors- Anyone Have A Source For Them?
Looking for 2-piece brake rotors in 370mm x 30mm and 245mm x 24mm for BMW F30. I know that ECS/ Turner sell really expensive 340mm and 370mm 2-piece rotors for the front only. There are many sources out that there for solid rotors. There must be companies that make/sell 2-piece rotors also. Any information is appreciated. Thanks!
John UPDATE: Thanks for the responses. To be clear, I am searching for 2-Piece Floating Hat type rotors. I am well aware of the other rotor offerings. It is the floating hat types that I haven't seen in the marketplace for the 370mm front and 345mm rear, other than the 370 front that ECS/Turner Motorsports both sell. I have to believe that there are more manufacturers out there that I have not heard about. Last edited by johnung; 04-30-2019 at 11:40 PM.. Reason: clarity |
04-30-2019, 04:34 PM | #2 |
Rep 1,325
From my understanding places that do two piece are about the same price as getting genuine m performance ones so may as well go to the dealer. Or were you after similar priced alternatives?
Otherwise Zimmermann do good one piece aftermarket in a variety of finishes (drilled/slotted/combination) or here in the UK MTEC do them as well both can be had for about £150 a pair for 370mm fronts and slightly less for rears. I’m told unless you’re tracking it or otherwise a fanatic you’re unlikely to notice the different of not having the lighter bell but I stand to be corrected. |
04-30-2019, 04:41 PM | #3 |
Boost Addict
344
Rep 349
RockAuto has 2 piece Aluminium hat rotors for 370mm for ~ $130 ea
Both blank and slotted/dimpled. https://www.rockauto.com/en/parts/pa...831,rotor,1896
S55 M2C | Three Pedal Club | E30TU
04-30-2019, 07:23 PM | #4 | |
Rep 3,549
If you're talking about two piece in the sense of those styled similar to BBKs that are semi/floating, then ECS and Stoptech Aerorotors are the only options I know of unless you want to do something custom like Adam's Rotors. FWIW, the Aerorotors have more wear thickness than OE (2mm vs 1.6mm), but the friction ring replacements are like $335 a piece...
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
04-30-2019, 08:38 PM | #5 | ||
Rep 5,413
04-30-2019, 09:31 PM | #6 | |
Rep 3,958
04-30-2019, 10:29 PM | #7 |
Rep 402
Drives: F87 M2C
R1 Concepts started offering 2-piece 370mm rotors but no 345mm for the rears.
When I upgraded my brakes I ordered through buycarparts.co.uk. Took a chance as it seemed a little sketchy but I got Brembo dimpled/slotted 370/345 2-piece rotors shipped for under $600.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
05-01-2019, 05:36 PM | #8 |
Boost Addict
344
Rep 349
The ones I linked are Pagids.
05-04-2019, 07:20 AM | #9 |
Rep 1,934
The dimensions and offset don't make it possible to have a true floating 2piece rotor. There's a thread somwhere here where the dimensions are measured and sent to a rotor supplier overseas. Pretty detailed.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
05-04-2019, 07:42 AM | #10 |
PdV Motorsports
121
Rep 165
Drives: 2014 335i xDrive sedan
Have a link or what to search for? I'm not finding anything and would like to read it.
Ryan M. PdVMotorsports.com Owner https://www.youtube.com/@pdvmotorsports
2014 EB M-Sport 335i xDrive - PdV/BC custom coilovers, PdV spherical rear shock mounts, PdV big brake kit, MHD Stage 2+ Next up: PdV genuine GTX3582R Gen2 turbo kit, Nostrum HPFP & Stage 2 injectors, PdV PM5 w/ "Veyron" Bosch E5LM |
05-04-2019, 09:32 AM | #11 |
Rep 5,413
That doesn't make sense to me only because Brembo makes them to fit the F30 in their Brembo GT brake kits, just not in a 370x30 size.
05-04-2019, 10:15 AM | #12 | |
Rep 1,934
05-04-2019, 10:21 AM | #13 | |
Rep 1,934
Just searched for 370mm 2 piece rotor
RbBugBitMe121.00 |
07-23-2019, 01:53 PM | #14 |
Rep 370
Im very interested in any news about F30 FLOATING front rotors...
The only other company that ive found is Stoptech - Stoptech Aero Rotors and Rotor Kits F3X 335i 435i Anyone else found anything?
07-23-2019, 04:26 PM | #15 | |
Rep 5,413
Brembo provides very similar floating two-piece rotors in their BremboGT big brake kits. But those big brake kit rotors come in various sizes but they are all about 4mm thicker than BMW rotors so none of those can be used with M Performance calipers. For instance, M Performance Brembo 2-piston rear calipers use rotors that are 345mm x 24mm thick. There is a BremboGT 4-piston rear caliper that uses a 345mm rotor, but it is 4mm thicker at 28mm. The BremboGT brake kits are extremely expensive and would cost about $8,000 to do all four corners. |
