BMW 5-Series (G30) Forum Engine, Exhaust, Drivetrain, Tuning Modifications RaceChip GTS Black G30 M550 results...
      04-30-2019, 04:34 PM   #1
ellisina4
ellisina4's Avatar
Drives: 2021 M5C
Hello all,
I wanted to share my results for RaceChip GTS Black on my G30 M550 that I purchased from Ben r33_RGSport
Equipment:
- 2015 F10 550i, retired, JB+, DashCommand
- 2018 G30 M550, current car, RaceChip GTS Black on Map 7, Dragy
Testing conditions:
April 2016 for F10, outside Temp around 45F
April 2019 for G30, outside Temp between 41 and 48F
I have been taking the same route to work for the last 6 years. Testing was done on the same stretch of the road, similar weather conditions and the same distance from home. This is true for the Stock/Tuned pulls on G30 as well as original testing with my F10. F10 info was detailed in the following post.
https://f10.5post.com/forums/showthread.php?t=1246548
Last Thursday I received Dragy and tested the car in stock mode. I performed five back to back 60-100mph pulls. The range was 5.47 to 5.67 seconds. Which is 0.2 seconds faster than my F10 550i with JB+. This just proves the fact that G30 M550 is way underrated.
I installed RaceChip GTS Black over the weekend. Install was as easy as described in the instruction that Ben sent me, about 30min. I was able to skip step 4 that required the removal of the air boxes.
On Monday, with the similar weather and on the same stretch of the road, I performed five 60-100 pulls back to back. The range was 4.78 to 4.95 seconds.
What can I say; I was not expecting 0.7 sec improvements with RaceChip from 60-100mph, especially since JB+ gave me 0.5sec on my old car. Power delivery is a smooth as stock, midrange is definitely improved. Coming from the standstill and using Launch Control, I now have a slight wheel spin.
Attached are the Dragy screenshots of the best 60-100 pulls, stock and with RaceChip GTS Black.
r33_RGSport13040.50
clee1982797.50
      04-30-2019, 04:48 PM   #2
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
@ellisina4 Thank you for your great review.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      04-30-2019, 06:53 PM   #3
modthispny
Drives: 2022 540i M sport
thanks for posting. happy to hear about the stock m550i performance compared to the 2015 with the jb+. what is a jb+ btw? is that jb4?
      04-30-2019, 06:58 PM   #4
ellisina4
ellisina4's Avatar
Drives: 2021 M5C
It's not JB4, It is JB+ and is also called BMS stage 1... should be equivalent to JB4 Map1
      04-30-2019, 08:55 PM   #5
clee1982
Drives: 2019 BMW 540i xDrive
550 is really a beast
      05-01-2019, 11:55 PM   #6
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Thank you for sharing
https://x-ph.com/sale/
Phone number 702-494-9435
      05-02-2019, 06:07 PM   #7
tjohnson
tjohnson's Avatar
131
Drives: 2024 iX50
2024 BMW iX50  [0.00]
Does anyone have a way to calculate the HP gain based on these results?? I have one that works for 0-60mph times, but 60-100mph is much different.
      05-07-2019, 09:17 PM   #8
12bmw535xi
Drives: 2019 M550
I was curious how will the BPM Stage 1 compare to Racechip GTS and did one pull today on the way from work...
      05-07-2019, 10:54 PM   #9
ellisina4
ellisina4's Avatar
Drives: 2021 M5C
Same altitude and same outside temp as during my testing... you are over 0.5 sec faster than me 60-100... mine is a piggyback and yours is flash... all makes sense.
At the same time, if I dropped 0.7sec from stock and you dropped another 0.5sec... that means that you dropped more than 1sec in 1/4 mile... considering stock car does 12.1-12.2 and the fastest we have seen is 10.9 on the dragy with stage 2 flash... either you have m850 engine or something is going on... lol
Have you tried doing a few runs in stock mode... if not, can you? Would love to see the delta the same way I showed in my testing.
I am in northwest suburbs, let's meet up for a run.
      05-07-2019, 11:09 PM   #10
12bmw535xi
Drives: 2019 M550
Damn man, I didn't realize you are this close. I'm in Algonquin.
I did 0-60 and couldn't do better then 3.69... so not sure how would the 1/4 go. I'm planning to visit Great Lakes Strip pretty soon if you want to join.
      05-12-2019, 01:33 AM   #11
bioman
Drives: E30
What setting was your Racechip on?
Looks like BPM is a better tune. Is it a piggyback or flash? Remote flash?
      05-12-2019, 01:20 PM   #12
ellisina4
ellisina4's Avatar
Drives: 2021 M5C
I am on Map7. It is a piggyback.
You would expect the flash to be faster, but not knowing the stock 60-100 time, it is hard to judge. If the user dropped 1.2 sec 60-10, that means he has 10 sec 1/4, something that is not possible for stage 1 flash. Plus, he only did one run and sometimes you see flukes... one of my runs was 4.1 and I ignored it.
r33_RGSport13040.50
      05-13-2019, 01:44 PM   #13
Sheharyar_rr
Drives: 14' 335xi M-Sport
It would be better if you guys stuck to 60-130mph which is the standard benchmark everyone uses. 60-100 doesn't tell much. I've gotten 60-100 better than F90 yet my 60-130 was worse. For reference my car does 60-100 in about 3.9. If 60-130 Is too much for you then do 100-200km/h which also everyone uses and can compare easily
2021 M5 Competition | Imola red
2020 Z4 M40i | Misano blue Pure850/PI/LPFP
Gone: 2018 M550i xDrive | DME Tuning BEF / JB4 / BM3 / DPs | 10.95 @ 125 1/4 Mile
Gone: 2014 335i xDrive | Bootmod3 Stage 2 93 Map | 12.2 @ 113 1/4 Mile
      05-13-2019, 08:00 PM   #14
12bmw535xi
Drives: 2019 M550
Problem is that 60-130 is pretty hard to do on a public road. 60-100mph is still popular and definitely more safe.
Check out this link for reference : http://www.torquestats.com/index.php...ive_filter=all
      05-14-2019, 10:05 AM   #15
12bmw535xi
Drives: 2019 M550
I did one today... probably "fluke" again
r33_RGSport13040.50
      05-16-2019, 06:15 PM   #16
ellisina4
ellisina4's Avatar
Drives: 2021 M5C
My apologies for the "fluke" reference... I was referring to my 4.1sec 60-100 run.
4.3 is awesome... you should be about 3-4 car length ahead of me since I am at 4.8.
Let me know next time you are planning to Great Lake track.
      05-16-2019, 10:35 PM   #17
12bmw535xi
Drives: 2019 M550
No offense taken! No need to apologize! I will hit you up when I plan to go for sure. For now weather is not permitting, maybe hopefully next week.
In a meantime going to Automotion tomorrow and staying there for the weekend.
      07-29-2019, 04:05 AM   #18
WMA1979
Drives: 2017 G30 M550i xDrive
Can you share the specific RaceChip installation instruction for G30 M550i. The instructions provided online is generic and not applicable to M550.
Thank you,
      07-29-2019, 10:15 AM   #19
ellisina4
ellisina4's Avatar
Drives: 2021 M5C
Thank you,
I would have Ben from RGSports provide these as they worked out for me perfectly.
r33_RGSport13040.50
      07-29-2019, 10:48 AM   #20
WMA1979
Thanks, so I assume that RGSports did the installation for u. In other words, u didn’t buy it directly from them and installed it yourself.
Will wait for RGSports to respond
r33_RGSport13040.50
      07-29-2019, 10:49 AM   #21
ellisina4
ellisina4's Avatar
Drives: 2021 M5C
Thanks, so I assume that RGSports did the installation for u. In other words, u didn't buy it directly from them and installed it yourself.
I bought it from them and installed myself.. very easy and instructions were great.
r33_RGSport13040.50
      08-01-2019, 10:09 PM   #22
WMA1979
Is it possible to share the installation instructions?
5post
