05-01-2019, 09:27 AM | #1 |
Rep 53
Harman Kardon Sound System standard with M Sport package?
I just checked my VIN number on https://www.mdecoder.com
It says there is a Harman Kardon Sound System. I was under the impression that this is an option and I did not ask for Harman Kardon System. So wondering if this is standard on BMW X5s? My config: BMW X5 2019 with M Sport Package. |
05-01-2019, 09:40 AM | #4 |
Rep 87
Drives: 2019 BMW X5 XDRIVE 40I M SPORT
I paid for my Harmon kardon on my m sport 40i.
05-01-2019, 09:46 AM | #5 |
Rep 53
05-01-2019, 09:48 AM | #6 |
Rep 20,420
05-01-2019, 11:25 AM | #8 |
Rep 2,610
Keep in my we don't all reside in the same countries and BMW has a long established tradition of packaging things completely differently in different countries. In Canada, I believe HK is standard on both 40i and 50i. I would not at all be surprised that it is an option and/or part of package in US — BMW Canada tends to bundle many things together and BMW NA (US) tends to have much more a la carte.
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
05-01-2019, 11:47 AM | #9 | |
Rep 53
05-01-2019, 11:57 AM | #10 |
Rep 2,610
I am in Canada. Don't have the car yet, but a) it is 40i M Package, b) better have the HK system! (I am sure it does :-)), and c) I did not order it explicitly (ie standard). In Canada, M package had nothing to do with it, HK is standard.
05-01-2019, 11:58 AM | #11 |
Rep 53
Oh yes you are from Canada. Did you get your VIN? Have you checked what it says? HK as standard will be awesome
05-01-2019, 12:45 PM | #12 |
Rep 87
I got mine in New Jersey. You should call your dealership and check your build. If you don't have it you may still have time to add it.
05-01-2019, 01:00 PM | #13 |
Rep 35
So in Canada, there's three packages
1. Essential (low tier) 2. Enhanced (medium) 3. Excellence (top tier) When I placed my order in Toronto (a month ago), I had to get the Enhanced package in order to get comfort access and Harmon Kardon. A side note, the standard audio system offered in Essential package is also a product of Harmon Kardon, maybe the reason why the name shows up with VIN#. |
05-01-2019, 01:13 PM | #14 |
Rep 53
Audio System Standard Features
Harman Kardon Surround Sound Audio System with vehicle-specific equalizing and powerful 600-watt amplifier - 16-speaker system includes 7 tweeters, 4 midrange speakers located in the door panels and 2 midrange speakers located under the rear shelf space, 2 bass speakers located under the front seats and 1 midrange center channel speaker. https://www.overseasbmw.com/carresea...ment/id_41438/ playin_harsh I think you are correct. May be the standard sound system is HK. However, if we order special HK it should be the premium sound system from HK too. |
05-01-2019, 02:48 PM | #15 |
Rep 53
So I went back and looked for VINs 100-150 numbers behind mine. The list says
S676A HiFi Speaker System However, mine shows S688A HarmanKardon Surround Sound System |
05-01-2019, 02:55 PM | #16 |
Rep 20,420
05-01-2019, 02:58 PM | #17 |
Rep 3,552
Looking at the window stickers the 50i comes standard with HK Surround Sound, the 40i its a 875 upgrade.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0 2019 718 Cayman Base 2015 M235 Manual On the list for the M2 CS |
05-01-2019, 03:04 PM | #18 |
Rep 20,420
Not according to the build. You need to select at least the Premium Enhanced package to get the HK otherwise it shows the HiFi Sound System as standard.
05-01-2019, 03:22 PM | #19 |
Rep 35
What I meant was the "hifi" sound system is under Harmon Kardon Corp, hence the use of name. I'm quite sure it's not the actual "Harmon Kardon premium sound system" if you didn't select enhanced package
05-01-2019, 03:54 PM | #20 |
Rep 53
Yeah I am pretty sure. I did not order Harman Kardon because I think Hifi is good enough. I already have a Bose at home. However, VIN build shows
S688A HarmanKardon Surround Sound System Either it is a data entry error or a "special gift" from BMW (Less likely though) :P |
05-01-2019, 03:57 PM | #21 | |
Rep 53
05-01-2019, 04:04 PM | #22 |
Rep 20,420
I know you said you didn't order the HK system but did you choose any packages? Are you expecting to have comfort seats, laser lights, heated rear seats, etc.?
