More Tyre Issues
08-04-2008, 05:01 AM | #1 |
Rep 312
More Tyre Issues
OK Bridgestones sound a bit of a joke, am keen to move to non-RFT.
Can i keep rft on the front still or do i need to change all 4 tyres? Any recommondations for the tyres? |
08-04-2008, 07:41 AM | #2 |
Rep 5,493
Don't mix RFT and non-RFT - the difference in handling and sidewall flex etc is too great
I have now tried many different normal tyres and runflat versions, across different cars. By far the most consistent, comfortable and secure (and most expensive unfortunately) is the Michelin Pilot Sport 2. Closely behind is the Continental Conti Sport Contact 3 which has better wet weather handling characteristics in terms of a more neutral breakaway, but less outright grip and cornering ability in the dry. The Goodyear Eagle F1 is very good also, but the wear rate is a little higher and the noise/comfort levels not as good. Pirelli PZero Neros and Rossos follow in that order - what you'll find with the Neros in particular is that whilst grip levels are high in the dry, there is a slight graininess and knobbliness to the ride quality, which transmits itself as a minute vibration through the steering wheel and base of the seat. Not uncomfortable by any means, but noticeable all the same. If you want to retain the runflat system, then certainly the Michelin Pilot Sport ZP tyre (for zero pressure) is light years ahead of the Bridgestone and is now considered the market-leader in outright performance. And it's really almost as good as the non-RFT version. Expensive though!
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
08-04-2008, 07:47 AM | #3 | |
Rep 8,811
08-04-2008, 07:59 AM | #4 | |
Rep 286
330cdsport has non rft's on the front and rft's on the back, he doesnt have problems check out his post in this link along with the poll on recommend non rft's http://www.e90post.com/forums/showthread.php?t=153525 cheers |
08-04-2008, 07:59 AM | #5 |
Rep 312
thanks for the great intel, much appreciated. In the end I am getting 1 new Bridgestone Potenza 255 30 19 91Y for £344 to tie me over. On renewal of tyres i will change to Michelin as Bridgestone are utter rubbish and their supply chain is being run by a gimp. Some garages were asking for £400. Independants cant get hold of the tyre at all.
Curiously what happens to the sensors when you change over the tyres to Non-RFTs? Are they still there so if i ever switch back they will work automatically? Thanks S |
08-04-2008, 08:05 AM | #6 | |
Rep 286
08-04-2008, 08:14 AM | #7 | |
Rep 5,493
WHAT ON EARTH?!!! That's CRAZY money...!!! It's not worth doing that - you might as well get a set of Michelin Pilot Sport 2 ZP (Runflat) for the rear, and run on mixed tyres for a while. That isn't so much of a problem. Then when the fronts are worn, change them over to the Michelin Runflats and then you'll have a complete system. Believe me, the PS2 ZP tyres are fabulous in their own right, and are very nearly as good as the normal PS2s in terms of ride comfort. The handling characteristics and grip levels are predominantly the same anyway. (make sure they're not the original Pilot Sport 1 ZP ... the version 2 is light years better) With regard to the tyre pressure sensors - BMW used two systems, the TPMS sensors on the valve stems themselves, or otherwise the ABS sensors (by measuring differences in rotational speeds in this case). If the car has TPMS sensors, the tyre fitters will retain the use of the them and the valve stems, but just change the internal valve needle. If the car uses ABS sensors, then there's no change whatsoever. Bottom line, don't worry!
08-04-2008, 08:19 AM | #8 |
Rep 312
Michelin Pilot Sport 2 ZP , where do you get them from, I have searched databases at:
national tyres Kwik Fit Event Tyres Elite Direct Black Circles Borehamwood Tyres BMW Watford and Stanmore E-tyres and Mr Tyres! |
08-04-2008, 08:23 AM | #9 | |
Rep 5,493
08-04-2008, 09:25 AM | #10 | |
Right Responsible
58
Rep 1,646
I have been running the non-RFT Falkens on the front alongside the original Bridgestone RFT's on the rear, and have found no problems with the mixed setup at all. Handling is spot-on. I intend to replace the rears with Falkens though when the Bridgestones are worn out (too tight to do it beforehand) So far, I am very happy with the Falkens on the front. They were recommeneded to me by Mikem on here.
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys. |
08-04-2008, 09:34 AM | #11 | |
Rep 286
have a few thousand left on the rears.. (well thats what i keep telling myself) |
08-04-2008, 02:54 PM | #12 |
Rep 623
Drives: F10 530d M Sport, E87 118d M
What are you planning to do about puncture repairs when you move to non RFTs? Are you planning on buying a spare, using some kind of gunk or performing a temporary patch repair?
I will be changing to non RFTs when mine need changing so just wondered what Plan B is for you? Tony
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
08-04-2008, 03:19 PM | #13 |
Rep 5,493
My Plan B is the M Mobility kit I got from BMW - gunk, compressor, to get you home. Plan C is call BMW Emergency Services.
08-04-2008, 03:55 PM | #14 | |
Rep 286
I know it doesnt help you being over there but you might want to ask yourself the question |
08-04-2008, 04:05 PM | #15 | |
Rep 5,493
08-05-2008, 12:44 AM | #16 |
Rep 3,658
Drives: E70 X5 xDrive35d M Sport
Garage List 2011 BMW S1000RR Sport [10.00]
2009 E92 M3 DCT [0.00] 2010 Range Rover Sport [0.00] 54 Plate E46 M3 CSL [0.00] |
Very good point Tony.
E70 X5 xDrive35d M Sport - Carbon Black - Panoramic Roof - 21" BMW Alloys - BMW Performance Gloss Black Grilles - LCi Rear Light Upgrade - BMW 4.8i Exhaust Trims
08-05-2008, 01:32 AM | #17 |
Rep 286
08-05-2008, 01:40 AM | #18 |
Rep 286
08-05-2008, 01:42 AM | #19 |
Rep 1,339
Drives: X1 25D M sport
Stop worrying...many of my clients have older supercars like Tony explains...they get no shit no hassle at all...Go get a MOT its easy..we are talking Bomb proof german BMW here...not some piece of 3 yo shit
08-05-2008, 03:27 AM | #20 |
Rep 9,915
Drives: VW T5
andy69, have you had any dealings with Jock Campbell from English Mobile Mechanics?
08-05-2008, 03:37 AM | #21 |
Rep 286
08-05-2008, 03:45 AM | #22 |
Rep 8,093
There is no requirement in the MOT to have a spare tyre of any description, much less a motorbility set-up. The ony requirement with an MOT is if a spare tyre is present then it must be road-legal. If it's not there at all then no problem. The BMW Mini has no spare and many examples of those (including my wife's) are of MOT age.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
