Whiteline 2012+ BMW Front Radius/Upper Arm Castor Bushing Kit |
05-08-2019, 09:41 PM | #1 |
Supreme Allied Commander
3886
Rep 54,505
Drives: F80 M3
Features
Engineered to alter/optimisecasteralignment tomaximizetyrecontactpatchduringroll, improve turn-in response & increase directional stability. Protective powder coating acts as a hard skin that is much tougher than conventional paint allowing this product to withstand the toughest conditions and resist corrosion for years to come. Featuring premium anodized alloy materials, Whiteline alloy products are anodized providing a long-lasting protective barrier to corrosion and wear but they look great too. Protective plating on all metal components acts as a hard skin that is much tougher than conventional paint allowing this product to withstand the toughest conditions and resist corrosion for years to come. Whiteline's latest technology synthetic elastomer formulation boasts resistance to oil, grease,ozoneandweathering. Supplied with extreme pressuremolybdenumdisulphide(LM) based grease for extended life. 70mm OD, Tube 95mm L - adds +/- 1.5deg caster Kits Required: 1 Warranty: 3 Year / 60,000Kms Kit Contents: 2 Bushings, 2 Tubes, Adjusting Tool, Install Guide, Grease Whiteline caster kits are designed to improve cornering grip and vehicle straight line stability through increased static caster and dynamic negative camber gain. In addition, synthetic elastomer bushings provide improved steering feedback and braking performance. KCA473 is suitable for the following vehicles. Select a vehicle for specific fitment details: BMW 1 SERIES F20, F21(8/2011-ON) BMW 2 SERIES F22, F23, F45(10/2013-ON) BMW 3 SERIES F30, F31, F34, F80(3/2011-ON) BMW 4 SERIES F32, F33, F36, F82, F83(7/2013-ON) Order here: https://www.hpashop.com/products/haw...4290622a&_ss=r Last edited by HP Autosport; 10-20-2023 at 07:07 PM.. |
