05-13-2019, 11:08 PM | #1 |
Rep 243
Wheel vibration (even after balancing)
Had my new tires/wheels (18x8) balanced 3 times and still having a vibration problem from 45 to 60 mph. After 60 a slight vibration then at 70 the vibration goes away.
It does not vibrates while braking and did not do it with the OEM wheels This is getting me frustrated ... Has anyone has experience this issue? |
05-13-2019, 11:19 PM | #2 | |
Not so new anymore
25
Rep 68
05-13-2019, 11:23 PM | #3 |
Luxury at the redline :)
9108
Rep 7,563
The wheels are probably bent, I found out I had three stock wheels bent and I didn't even know until the dealer tech showed me by spinning the wheels on the vehicle, while in suspense on a lift.
If it's bent, you'll see it wobble as it spins. |
05-13-2019, 11:26 PM | #4 |
Rep 243
They are 18x8 aftermarket wheels with new tires. I did not had that issue with the OEM even that 2 were slightly bent.
05-13-2019, 11:28 PM | #5 | |
Rep 243
I saw them torque the wheels ... |
05-14-2019, 12:19 AM | #6 |
Rep 233
Drives: '18 M2 LCI
Maybe take it to a shop to measure if the wheel is bent
'18 M2 LCI 6spd
05-14-2019, 05:37 AM | #7 |
Rep 6,087
Find a shop with a Hunter Road Force balancer. This machine will assess the relative high and low mass points of the wheel versus tire. Sometimes, the solution is to partially rotate the tire on the wheel to offset small differences in uneven mass.
paposalsa50.50 |
05-14-2019, 07:55 AM | #8 |
Rep 243
Thanks, that is what seems to be the fix and/or Hub Ring ...
05-14-2019, 07:56 AM | #9 |
Rep 6,087
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
paposalsa50.50 |
05-14-2019, 09:09 AM | #11 | ||
Not so new anymore
25
Rep 68
paposalsa50.50 |
05-14-2019, 02:04 PM | #12 |
Rep 5,394
Are the wheels hubcentric or do they required a hub ring?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
05-14-2019, 02:27 PM | #13 | |
Rep 3,507
I'm curious, did you have them balanced and re-balanced at the same shop; if so, by the same tech?
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
Dylan861330.00 |
05-14-2019, 09:26 PM | #14 | |
Rep 243
Same shop, for sure different Tech. Is Discount Tire ... But this time I going to ask for the Tech that had balance them the "best". Also going to request Road Force Balance They are hub centric ... |
05-14-2019, 10:13 PM | #15 | |
Rep 5,262
Have you tried putting the front wheels in the back ? |
05-15-2019, 08:40 AM | #16 |
Rep 970
Yes, this first.....had wheels changed on my Mini and the idiot installer didn't tighten all the lugs. It really showed up at around 45 MPH too.
Next, I'd check wheels for damage. A bent wheel may not look bent, but will certainly cause a shimmy and shake when rolling. Of course you'd think this would appear if they spin balance each wheel before installing. |
05-15-2019, 05:34 PM | #17 |
Rep 1,608
I had the problem with a gorgeous set of billet Fikse rims on my E36 M3; drove me crazy. I had road force balancing done with no improvement. Even though the wheels were hubcentric, the problem was solved when we decided to loosen and retorque all the lug bolts.. The trick is, for each wheel, loosen them up and one by one slightly tighten them in your normal cross hatch pattern, a tiny bit at a time on each bolt.. with each one, until theyre tightened down, grab the tire and try and 'Jimmy' it from side to side until youre sure youve got the center of each hole..... If precision rims like Fikse can cause these problems, then any after market wheel can.. After we performed this action, the vibration totally disappeared. On the fronts, you may have to have a friend sit in the car and step on the brake pedal in order find the center of each of the 5 lug holes.. Good luck!
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 |
paposalsa50.50 |
05-15-2019, 06:04 PM | #18 |
Rep 294
Drives: 2019 M240i Coupe RWD
When I was in a similar situation (having the tire store balance the wheels 3 times), I finally went to a different place he confirmed the wheels were off balance. The problem was the tire store, they never calibrated their roadforce machine and according to the guy I found, he used to train them but stopped because they were all idiots. Needless to say I won't be going to that tire store anymore.
paposalsa50.50 |
05-16-2019, 08:46 PM | #19 |
Rep 243
01-01-2022, 11:27 AM | #20 |
Rep 48
I know another old thread but wondered if you ever figured out your problem paposalsa, mine does the same thing at the same speeds and is driving me nuts. I so wanted to love the car but this issue is keeping me from it.
