Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Esys on G20
      05-15-2019, 09:39 PM   #1
CyclingBroStyle
CyclingBroStyle's Avatar
Drives: '19 330i xDrive M Sport
Esys on G20
What's the status has anyone coded their G20 using esys? If so what have you coded?
Current: MY2019 330i xDrive M-Sport w/Lasers - Portimao Blue
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey
BMW CCA #522637 use me as a referral for BMW CCA
      05-27-2019, 07:56 PM   #2
simsimma777
Drives: 2019 M850i coupe
I managed to code ASS to stay off using Esys.
Haven’t been able to code anything else yet as there is no cheat sheet for G chassis to reference, and things are quite different from the F chassis.
      05-27-2019, 11:18 PM   #3
claykin
Drives: various BMW
What tool are you planning to use to do FDL coding?
Many G30 coding cheats work on G20. Tread lightly where you know there's differences such as the HEADUNIT module (iDrive) until we learn more.
2023 840GC | 2021 740i | 2019 X3
      06-04-2019, 12:08 AM   #4
simsimma777
Ok so managed to code a few more things now using esys.
I downloaded the newest launcher pro released by token master a few days ago. He responded within a day to my email, and a few minutes after the donation I got the download links.
Connected to the car using S18A, then followed some old cheat sheets like the F15 to code the following:
Disable disclaimers
Zoom on reverse camera
Turned off honking when locking car with engine running
M startup animation
Windows roll up with door open (forgot to test this)
I couldn’t figure out how to set the turn signal to blink 4 times, but overall happy that the G20 is now codable.
      06-04-2019, 10:24 AM   #5
CyclingBroStyle
What about sport + can that be coded?
      06-06-2019, 10:10 AM   #6
simsimma777
I’m sure it can but haven’t tried. Hoping someone can lead the way on this one first.
      06-06-2019, 07:22 PM   #7
phillyd2
Drives: 2020 M340i XDrive
You can configure Sports to Sports + in idrive.
      06-08-2019, 07:48 PM   #8
CyclingBroStyle
Not in US on the 330i
      06-12-2019, 03:02 PM   #9
ring0r
Germany
101
Drives: G20 330i
Sadly I don't get a message from tokenmaster so I can't start to coding... :/
      06-13-2019, 09:10 AM   #10
OldOne
Drives: '20 M340i
Apparently there is another option now:
https://f30.bimmerpost.com/forums/sh....php?t=1605618
(haven't tried it myself yet)
      06-15-2019, 05:06 AM   #11
Stiunit
Stiunit's Avatar
23
Drives: 2020 M340I
i want to get video in motion coded
      06-15-2019, 06:11 AM   #12
hallamnet
Drives: G20 320d 2019
Ass Coding
Hi there.
What ecu is this stored in and what is the option name called?
I have searched everywhere and cannot find it!
Thanks,
Hal
      06-16-2019, 10:05 PM   #13
simsimma777
Originally Posted by hallamnet View Post
Hi there.
Thanks,
Hal
In DME, search for TCM_MSA_MEMORY, and set to Wert_01.
mzdial117.00
      06-19-2019, 08:45 AM   #14
RoopD
Drives: F30 Alpine Weiss
Hi,
Is Navigation Plus in a G20 the same as Navigation Professional (on my F30)?
      06-20-2019, 06:20 PM   #15
smartguy
Drives: BMW F30 320D
When i try code the Ass option, it all looks fine writing the ecu but in the end car shuts down, computer resets and programming is not complete. What goes wrong? Do i have to use diagnostic mode?
The only parameter i code at that time is the ASS option as described..
      06-21-2019, 09:12 AM   #16
simsimma777
You should code DME with the engine off. That might be it.
      07-07-2019, 05:19 PM   #17
ballisma
Drives: G20 330i
Going against the grain here
Is it possible to increase ASS/ASD?
      07-13-2019, 09:48 PM   #18
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
I have not tried in awhile, but most coding changes to ASD (since 2015) just end up disabling.
      07-29-2019, 03:19 AM   #19
vahihapehe
Drives: BMW F25
Hi all, in the weekend I've tried to connect to a G20 with this esys configuration:
- VMware win 7 32bit
- esys 3.27.1
- launcher premium
- psdzdata_lite_4.18.22
I've connected to the car, read data from ECU's, but cannot understand them (most of all was trimmed, both from esys and with ncdcaftool).
Do I have to use a different esys version, or a different launcher?
Maybe "launcher pro 2.8.2 build 162" (but it would not work inside VM)?
i'm thinking on buying a pro license directly from tokenmaster, but need to know if the pro can work on VM and if it can read newest car data.
      07-31-2019, 02:14 AM   #20
Almaretto
Almaretto's Avatar
2374
- esys 3.27.1
- launcher premium
Premium will not work for a G20.
Pro can be used on VM.
      07-31-2019, 03:21 AM   #21
ahmedhamdy
Drives: 2015 Merc C180
What about Active Sound?
      07-31-2019, 03:50 AM   #22
Almaretto
Almaretto's Avatar
2374
What about it?
g20
