06-11-2019, 09:23 PM | #1 |
Rep 429
No internet when on Carplay
Hey everyone:
I am able to connect to Carplay but my phone becomes useless meaning with no internet access to things like google etc. whenever carplay is active. it just keeps clocking but goes no where. I have to turn off my wifi on the phone to get the phone to browse the internet. Anyone else have this issue as well on the G05? Any fixes ? |
06-12-2019, 06:04 AM | #2 |
Rep 24
It's most likely the phone trying to connect to the car's wifi and the wifi isn't active. You should be able to disable it in the CarPlay settings or just 'forget' the network from the phone.
06-12-2019, 11:12 AM | #3 |
Rep 214
Go to Mobile Devices and Settings. Turn off everything and ONLY turn on CarPlay. That should enable bluetooth and wifi (CarPlay uses both). If I am remembering correctly there is an "Internet" checkbox. You have to turn that off.
The reason you lose internet is because the car is trying to give your phone internet and if you don't have a hotspot subscription it won't work.
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i |
MissVito217.50 |
06-16-2019, 09:34 AM | #4 | |
Rep 429
06-16-2019, 05:14 PM | #5 | |
Rep 214
If you HAVE hotspot subscription and your phone can't connect through the car's internet, then there is another issue.
06-18-2019, 08:34 AM | #7 |
Rep 214
Like I said before, turn off the "internet" option, that is the only way it will work. That internet toggle is to share the hotspot feature with the phone. You don't have hotspot and if that toggle is on, that is why your phone internet is not working. Mine works fine with WiFi and Bluetooth ON, but internet off.
06-24-2019, 05:21 PM | #8 | |
Rep 429
07-14-2019, 08:46 PM | #9 | |
Rep 2,053
. Do what this guy says using your idrive.
Moved to the darkside: '23 718 GT4; 11-10-2022.
Le Mans Blue F80 - Munich 5-22-2015 / US 7-7-2015 / SOLD 9-17-2022 ED RecapArctic Grey G05 - Spartanburg 8-29-2019 X5 PCD Recap |
10-04-2020, 11:15 AM | #11 | |
Rep 20,149
Depending on what iDrive version you have the wording/options may be a little different. I can post a pic of what it should look like in 07/2020.xx if needed. |
10-10-2020, 12:47 PM | #12 |
Rep 1,780
I ran into this situation for the first time yesterday. I've had iOS 14 ever since it came out and I never really paid much attention to carplay because I only really just use it for music. But today I needed to use it for Apple Maps navigation and the navigation got stuck at one point trying to 'reroute' me. I opened my phone and saw I had no internet going to my phone via carplay. This was never an issue with iOS 13. I had to get the phone to 'forget' the BMW network for it to work.
Everything *seems* like it works as it should now, but I'm wondering if it's now re-routing my phone through bluetooth... Edit: I just now un-paired and repaired my phone to idrive carplay. It seems to be working as it was in ios 13. My phone shows its connected to the BMW wifi, but I tested a few apps and the internet was working as it should on my phone while carplay was also active in the idrive screen. Last edited by thereef510; 10-10-2020 at 03:34 PM.. |
10-17-2020, 01:36 PM | #13 |
Rep 35
When you pair the phone via Bluetooth you will be prompted to connect to WiFi as one of the last steps. Decline that option unless you have hotspot with internet access enabled. Otherwise, the WiFi connection will be to the BMW hotspot without internet capability. When you decline this option, the phone will use cell service as needed.
volodp199.50 |
10-17-2020, 01:44 PM | #14 |
Rep 419
@TheHitchhiker is right. See this related thread.
https://www.bimmerpost.com/forums/sh...php?p=26514099
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs] |
10-19-2020, 03:39 PM | #15 |
Rep 1,952
I'm experiencing this same issue. For me, what has happened is that I subscribed to the internet HotSpot plan for a trip my family was going on. When I did that my phone would connect to the BWM wifi for internet so the car created a new device just for that. So my cell phone has two devices in iDrive.
A wifi only and a carpaly version. Now the car thinks there's two devices connected "VTENGR-Cell" (used only for internet - only the wifi icon shows in device manager) and "VTENGR Cell" (used for CarPlay - phone, app and wifi icon in device manager). The problem is "VTENGR-Cell" is connected to wifi looking for data, so my phone can't get internet while it's connected. If "VTENGR Cell" connects first, than it's a non issue. No matter what I do I can't get rid of the "VTENGR-Cell" device. I guess the last resort would be removing my device from iDrive altogether but I don't want to do that if I don't have to. edit: The "Internet WiFi" setting it not toggled in idrive - just the regular WiFi that you need to run CarPlay is toggled. Last edited by VTENGR; 10-19-2020 at 03:50 PM.. |
11-08-2020, 10:15 AM | #17 |
Rep 20,149
It could have originally been paired incorrectly. Remove the phone from iDrive and forget the connection on your phone and restart it. Then go through the pairing process again using bluetooth and allowing the CarPlay connection.
11-08-2020, 10:08 PM | #18 | |
Rep 7
BUT - I figured it out (I think someone else pointed that out as well). I changed my iPhone’s name to say “Michael’s iPhone”. It appears BMW does not like that as it looks for just generic “iPhone” to connect to (and yes, I deleted all previously installed devices from the iDrive). After I changed iPHone’s name back to “iPhone”, all is well. I get CarPlay to come up as soon as I enter the car (wirelessly) and I am able to connect to the internet. The cellular indicator on infotainment’s screen in CarPlay mode now says “5G” whereas before it would display a WIFI icon. FWIW, I am on iOS 14.2 |
TurtleBoy13511.50 |
11-17-2020, 09:14 AM | #19 | |
Rep 165
f25@110K and counting...
01-17-2021, 09:25 AM | #20 |
Rep 1,179
I was having this same issue on my 3 series. I’d tried deleting the phone pairing on the car and the car from the phone (Bluetooth, Wi-fi & CarPlay). I’d paired again several times but with no joy.
After reading this thread I tried again but this time after deleting the pairing I changed my iPhones name under Settings - General - About from “Steve iPhone XS Max” to “Steve iPhone XS”. I then went through the pairing process again and it worked! As mentioned above, the first thing I noticed this time, was when it connected to CarPlay, the iPhone was showing the 4G icon this time and not the Wifi symbol. |
02-23-2021, 04:11 PM | #21 |
Rep 8
When I have WiFi unchecked and left Bluetooth checked, android turn off.
I turned off my wifi on the phone and start Android auto in the car, it 1turns on the wifi on my phone and connects to the car. Is there anyway I can use Android auto with bluetooth only? I want to connect my phone wifi to a different router device and NOT to the car. |
02-23-2021, 07:13 PM | #22 | |
Rep 20,149
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
